BRAIDED HOSES FOR RS4 CONVERSION...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
ADYS4FKU
Post by ADYS4FKU » Mon May 05, 2008 8:21 pm
Need some advice. Just won some RS4 front brakes on ebay.
What to fit some braided front brake hoses. Does anyone know which ones to buy? S4 saloons or A4 Quattro Est. Just need the fronts. Am running on 19" RS6 rep. Thanks in advance
docurley
RE: BRAIDED HOSES FOR RS4 CONVERSION...
Post by docurley » Mon May 05, 2008 11:30 pm
Get the RS4 brake lines as I have been told they are already braided.
BRETTCOLLINS
Post by BRETTCOLLINS » Tue May 06, 2008 3:55 pm
had mine made up.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
spen
Post by spen » Tue May 06, 2008 4:00 pm
Just buy audi oem, like docurley says they're braided internally. This means grit can't penetrate the braid and chaffe the actual pipe as can happen with regular braided hoses.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
Trig
Re: RE: BRAIDED HOSES FOR RS4 CONVERSION...
Post by Trig » Wed May 07, 2008 9:55 am
spen wrote:Just buy audi oem, like docurley says they're braided internally. This means grit can't penetrate the braid and chaffe the actual pipe as can happen with regular braided hoses.
Buy coated PTFE brake line and it keeps the <beep> out.
James Lister Motorsport can supply all the parts and make them yourself, dead easy!
mrmule
RE: Re: RE: BRAIDED HOSES FOR RS4 CONVERSION...
Post by mrmule » Tue May 25, 2010 10:15 am
will the rs4 ones you speak of ok for use with the standard B5 S4 calipers?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
jc..
Post by jc.. » Thu Jul 08, 2010 11:08 am
no point running uprated hoses on just the front.
the brakes work on two diagonal systems so if one front pipe is rock hard and the rears are 10 year old rubber you will still feel a spongey pedal if the pipes are bulging.
I had mine made up but to be honest having just refitted a rea subframe I removed two of the Goodridge Motorsport pipes and two of the rear hardlines and replaced four bits (2 hard 2 braid) with two Black diamond braided pipes I had left over from a Mk2 Golf project!.
so long as they are not too short or massively too long then a bit of extra length is not a bad thing (still talking about brake pipes here!).
Users browsing this forum: No registered users and 69 guests
