Brake wear sensors?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Dippy
Brake wear sensors?
Post by Dippy » Tue Mar 09, 2010 1:49 pm
I have the brake warning light (yellow - single beep) but no DTCs. I have had the ABS warning before, so suspect that I'll need to do the 'ECU fix' sometime in the future, but I don't think this is it now.
My front brake pad wear sensors are shorted out (due to my Porsche upgrades), so it would need to be the rears. Inspection without wheel removal suggests that the pads are about 5mm thick, maybe slightly less.
But I didn't think that the B5 had rear pad thickness sensors. Can anyone confirm?
2001 Silver S4 Avant
Blue_Thunder
RE: Brake wear sensors?
Post by Blue_Thunder » Tue Mar 09, 2010 4:11 pm
Not sure about pad wear sensors, but can say that when my ABS ECU died it was the red (!) symbol which appeared on the DIS.
So hopefully it won't be a problem with your ABS ECU.
