what injectors to fit in modded S4
hi
does anyone know which injectors to use for around 400hp on an s4? thanks
Blue_Thunder
- Top Gear
You should be able to get 400 on stock injectors but on a very high duty cycle - no headroom. As Scott says, you can get
more out of RS4 injectors but you have to be careful as the spray pattern is wrong which can lead to bore wash and other
problems. Also, would you fit second hand injectors without getting them serviced? My advice would be to get a new set
from a tuner which knows what they are doing. The 630cc injectors aren't as expensive as you might think.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Users browsing this forum: No registered users and 71 guests
