Snub Mount and Phoelinetic spacers fitting ?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
s2rsman
Post by s2rsman » Sat May 16, 2009 6:48 pm
Hey guys what's involved in fitting the above ?
i.e. How easy and what has to come off to achieve.
I'm about to get the cambelt done so wondered if this was the time to do a snub mount.
Also was going to order phoelinetics at the same time
but didn't want a huge labour bill to fit ?
Thanks.
andybnwc
RE: Snub Mount and Phoelinetic spacers fitting ?
Post by andybnwc » Sat May 16, 2009 9:38 pm
yes on the snub and pretty sure the intake spacer is straight forward
Blue_Thunder
Post by Blue_Thunder » Sun May 17, 2009 12:42 am
Wouldn't bother with the phenolic spacers whilst the cambelt is being done as they can be fitted with the front end on the car.
re: the cambelt, are you aware of all the other bits you should get done at the same time, ie: thermostat, water pump, etc.
s2rsman
Post by s2rsman » Sun May 17, 2009 8:44 am
Yep cambelt kit, rollers,tensioners, water pump,gasket, thermostat.
On the spacers I'll wait till I've recovered from the cambelt,
can it be a diy job ?
andybnwc
Post by andybnwc » Sun May 17, 2009 12:07 pm
yes you dont have to move much at all
s2rsman
Post by s2rsman » Sun May 17, 2009 3:14 pm
Had a look round today while doing the spark plugs, seen the bolts for the inlets.
It is simply a case of removing the top end stuff and installing them ?
any sealant required ?
jimbo1234567
Post by jimbo1234567 » Sun May 17, 2009 11:26 pm
no they come with gaskets. just remove the y pipe, fuel rail and inlet manifold .should take 2 hours tops
