Hey guys what's involved in fitting the above ?
i.e. How easy and what has to come off to achieve.
I'm about to get the cambelt done so wondered if this was the time to do a snub mount.
Also was going to order phoelinetics at the same time
but didn't want a huge labour bill to fit ?
Thanks.
Snub Mount and Phoelinetic spacers fitting ?
RE: Snub Mount and Phoelinetic spacers fitting ?
yes on the snub and pretty sure the intake spacer is straight forward
Blue_Thunder
- Top Gear
Wouldn't bother with the phenolic spacers whilst the cambelt is being done as they can be fitted with the front end on the car.
re: the cambelt, are you aware of all the other bits you should get done at the same time, ie: thermostat, water pump, etc.
jimbo1234567
- 5th Gear
no they come with gaskets. just remove the y pipe, fuel rail and inlet manifold .should take 2 hours tops
665 bhp + 586 lbft...
