engine cover wont go back on?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
andybnwc
Post by andybnwc » Wed Jan 07, 2009 7:58 pm
Was routing about while getting ready to move house and found my engine covers . Fitted both small side ones but the main one with V6 written on it wont fit . Its fouling with the throttle body boot sensor plug . I have venair boot . Should the plug point upwards slightly?
Blue_Thunder
RE: engine cover wont go back on?
Post by Blue_Thunder » Wed Jan 07, 2009 10:25 pm
Some aftermarket TBB's like Samco and Autobahn88 do stick up more than the stock items. You could try trimming it down a little, so long as you leave enough space for the clip which holds the sensor in place to get a good grip.
andybnwc
Post by andybnwc » Thu Jan 08, 2009 9:31 pm
Ill give it a go tmrw see how much i can get off it
frazered
Post by frazered » Thu Jan 08, 2009 11:02 pm
probably not a good idea to trim them - can cause boost leaks if not done properly - check your dv's are set the right way as these can interfere
i have my main cover left off atm with some samco hoses
andybnwc
Post by andybnwc » Fri Jan 09, 2009 10:31 am
The only bit sticking up is the sensor plug off the tbb , aslong as i can get a good hose clip on should be fine ill have a look in a min
Users browsing this forum: No registered users and 104 guests
