RS4 front brakes on pre facelift S4? Is it possible?
- 1st Gear
yes they do. and they should fit under the standard B5 wheels too
Disks are available from motorfactors for around 80quid a pair, which is significantly better than the £lots the RS4 disks cost!
In the case of RS4 disks, its probably cheaper to get a set of wilwood (or similar) bells and rotors made up to fit. Rally design do universal bells for about 60quid each (just need skimmed down to the exact size required) and 355mm disks to fit said bells for 140ish each. should work out a little bit cheaper than a set of RS4 disks the first time round, and more so for subsequent times...
You might even be able to find an aftermarket supplier who do rotors that will fit the audi RS4 bells.
Re: RS4 front brakes on pre facelift S4? Is it possible?
Do the rear Rs4 B7 brakes also fit on a S4/A4 B5 quattro?
Garaget.org: http://www.garaget.org/TheGuard
Project: http://www.garaget.org/forum/viewtopic.php?id=196330
Anyone want to sell their stock B5 calipers and carriers?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Users browsing this forum: No registered users and 58 guests
