Hoses to connect S4 ICs to RS4 charge pipes?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
CliveH
Post by CliveH » Sun Oct 05, 2008 3:51 pm
This is a bit of a longshot, but I'll post up before I go spending lots of money on alternative solutions or reinventing the wheel. Surely someone somewhere sometime must have connected stock S4 (or AWE) intercoolers to RS4 charge pipes...?
The stock (or Samco) hoses do not fit because the RS4 charge pipes are a bigger diameter to the S4 pipes (or APR bi-pipe) and also sit a bit higher.
The RS4 hoses do not work because the RS4 IC outlet pipes sit at a different angle to the S4 stock/AWE ICs.
Anyone done this or have any bright ideas...? :?
Clive
tartan_rob
RE: Hoses to connect S4 ICs to RS4 charge pipes?
Post by tartan_rob » Sun Oct 05, 2008 5:40 pm
Hi Clive. Long time no speak.
I'm going to get ready for some incoming as I'm sure this would have been your first thought...reducing or increasing diameter pipework? Rubber hoses onto some type of solid pipework?
2017 Kawasaki Z1000
2014 RS6
2014 S1
CliveH
Post by CliveH » Sun Oct 05, 2008 6:00 pm
How's things Rob? :bigwave:
The outlet from the ICs is 52mm and the inlet to the chargepipes is 65mm, and the shape of the hose then needs to be dogleg, just like the original S4 hoses.
Clive
dazzer
Post by dazzer » Sun Oct 05, 2008 8:21 pm
Guess ure having a rs4 head fitted then. Don't awe do the pipes!
CliveH
Post by CliveH » Sun Oct 05, 2008 8:27 pm
No Darren, as the AWE IC's exit pipes are the same size and orientation as the S4 stock ones, so fit straight onto the stock S4 hoses or Samco equivalents.
Clive
grizz
Post by grizz » Wed Oct 08, 2008 6:45 pm
Clive , Cant you use the rs4 rubber pipes and get the intercooler outlet modified to fit them .. ???
Unit 20
0151 3366888
CliveH
Post by CliveH » Wed Oct 08, 2008 9:58 pm
Yes, that's another idea I'm toying with Grizz
Clive
smurfbus
Post by smurfbus » Thu Oct 09, 2008 12:50 pm
Adapter piece from WMS or go to the gym and use the stock hose.
CliveH
WMS?
Post by CliveH » Thu Oct 09, 2008 2:12 pm
smurfbus wrote:Adapter piece from WMS
Do you have a link please?
smurfbus
RE: WMS?
Post by smurfbus » Mon Oct 13, 2008 5:35 am
I don't think they have it online. its a smaller dia alu piece you need to get welded on the rs4 uppipes to use the stock hose but I just used stock hose with some force. Been good this summer.
Users browsing this forum: Bing [Bot] and 24 guests
