new turbo's fitted
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
f1
Post by f1 » Mon Sep 29, 2008 4:03 pm
dazzer wrote:
f1 wrote:Right O Mr Britassssss! LoL
Is it your car or a customer's? Not being a britasssss - may just being doing you a favour LoL:
http://audisrs.com/about1875.html
Its my car and the companies demo i guess!
Seriously thank you for the heads up!
f1
Post by f1 » Wed Oct 01, 2008 11:01 am
Ok the next map will go on today! Hopefully this one will sort out the issue's that we had with the car!
Will update when i have more news!
andybnwc
Post by andybnwc » Wed Oct 01, 2008 3:16 pm
If this works does that mean they would find it easier to write one for my k04 based pre face lift. once the fuelling is done?
f1
Post by f1 » Wed Oct 01, 2008 5:18 pm
andybnwc wrote:If this works does that mean they would find it easier to write one for my k04 based pre face lift. once the fuelling is done?
Yes it does the new map is for k04's but with s4 fueling!
dazzer
Post by dazzer » Wed Oct 01, 2008 8:52 pm
Well they have already had some practice......that's what customer's cars are for.
andybnwc
Post by andybnwc » Wed Oct 01, 2008 9:33 pm
So will it be an easy tweak for say larger injectors and pump etc
frazered
Post by frazered » Wed Oct 01, 2008 9:45 pm
sounds like you are a guinea pig here - I would certainly not be happy with that going on to my car especially spending so much on new turbos etc...
Blue_Thunder
Post by Blue_Thunder » Wed Oct 01, 2008 10:10 pm
Seems a bit daft of Custom Code to be writing a base map for rare K03/K04 hybrids.
Thought they'd be better off sorting out K03 and K04 base maps first!
rs4steve
Post by rs4steve » Wed Oct 01, 2008 10:28 pm
goodridge wrote:
rs4steve wrote:i have a set of of k04/k03 hybrids on my car gave 394bhp / 580nm on powerstations rolling road when remapped boost was dropped from 1.9 peak to 1.7 tails then off to 1.4bar due to high egt's
Crike. Thats sounds impressive! More info please?
its this car intercoolers are rs6's ,
f1
Post by f1 » Thu Oct 02, 2008 11:13 am
frazered wrote:sounds like you are a guinea pig here - I would certainly not be happy with that going on to my car especially spending so much on new turbos etc...
Not at all! We are a custom-code dealer and are trying to get a map for the hybrid turbo's using standard injectors/intercoolers/engine and even exhaust!
We will however be putting a milltek on the car at a later date to see how much difference that will make!
They already have maps for the ko3 and ko4 set-ups this is a cheap 400bhp or there abouts,we wanted to do an s4 with good power for minimal outlay with no need to change major engine items!
We are now seeing around 320gps from the engine,and a very smooth boost curve,which is exactly what we wanted!
Blue_Thunder
Post by Blue_Thunder » Thu Oct 02, 2008 11:27 am
That is brave running that much boost on stock injectors!
Guess Custom Code aren't aware of AMD's early attempts to crack 400bhp on standard fuelling...
Hot! Hot! Hot!!!
f1
Post by f1 » Thu Oct 02, 2008 12:26 pm
Blue_Thunder wrote:That is brave running that much boost on stock injectors!
Hot! Hot! Hot!!!
Charge temps are fine so is the timing in fact its all ok! Obviously hasnt been checked in european summer temps but the map will sort itself out in high temp situations!
dazzer
Post by dazzer » Thu Oct 02, 2008 6:53 pm
They already have maps for the ko4 set-ups
I only know of one S4 that has a 'K04' map on from them!
f1
Post by f1 » Fri Oct 03, 2008 1:11 pm
My car has a modified K04 map on it! The do have dealers in the states as well so i guess they might of done more than 1!
S2tuner
Trader (Expired)
Post by S2tuner » Fri Oct 03, 2008 1:24 pm
Good luck trying to get 400 BHP out of stock injectors and K03 hot sides.
