Good morning chaps
I have a cluncking on my steering, low speed turns either way on the lock and around the middle of the travel not on the end stops. It sounds like it is actually in the dash board behind the stereo.
Any common faults that anyone is aware of?
Cheers in advance
Chris
Clunky steering
Clunky steering
Audi S4 B5 2.7 V6 TT quattro 1998 Silver
Suzuki GSXR750 1999 Blue/White
- mikeyquattro
- Top Gear
- mikeyquattro
- Top Gear
Justin:NorCal
Before you go replacing the steering rack there are 3 bolts holding it in place that can (not often), but can come loose. It is a 10mm 12point socket you will need. The one on the driver side is easily accessible and just behind the firewall. The passenger side will require that you remove the battery. It is directly beneath. The third one is accessible from underneath the car. You will need a long extension.
