I hate cars..... One thing after another...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
spen
Post by spen » Sun Jul 06, 2008 2:07 pm
Can anyone tell me the impact of disconnecting the gearbox oilcooler pipes and putting blanking plugs in place short term? Obviously the gearbox oil won't get cooled, but that is better than it leaking all over the place :( :oops:
Will anything happen to the oil pump inside the gearbox? Is there another route inside the box for the oil to flow around?
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
Trig
Re: I hate cars..... One thing after another...
Post by Trig » Sun Jul 06, 2008 5:54 pm
spen wrote:Can anyone tell me the impact of disconnecting the gearbox oilcooler pipes and putting blanking plugs in place short term? Obviously the gearbox oil won't get cooled, but that is better than it leaking all over the place :( :oops:
To prevent any possible damage, just go to any hydraulic hose place and get a link pipe to join the 2 together.
Cost..........£10?
musty1
RE: Re: I hate cars..... One thing after another...
Post by musty1 » Sun Jul 06, 2008 6:16 pm
I'm not running a gearbox cooler not had a problem so far
1.9TDI A6 are sh*t wrong forum
dummi
Post by dummi » Sun Jul 06, 2008 7:33 pm
a6's don't have one and are ok, safe bet is trig's pipe solution
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jul 06, 2008 7:51 pm
My S2 runs an s4 box with the ports linked together.
http://www.MRCtuning.com
spen
Post by spen » Sun Jul 06, 2008 7:56 pm
Anyone know, or can measure, the diameter of the banjo unions so I can order a link pipe?
Trig
Post by Trig » Sun Jul 06, 2008 9:31 pm
spen wrote:Anyone know, or can measure, the diameter of the banjo unions so I can order a link pipe?
You just need to know the thread size in the box, get some adaptors from gearbox thread to BSP, have a pipe made with BSP Swivel Females on the end and hey presto, JD!
grizz
Post by grizz » Sun Jul 06, 2008 10:03 pm
The b7 box has blanks on them , no oil cooler .
Unit 20
0151 3366888
spen
Post by spen » Sun Jul 06, 2008 10:43 pm
Cheers Grizz.
h8cak
Post by h8cak » Sun Jul 06, 2008 11:25 pm
So why have them if there not needed?
Wide Body S4
spen
Post by spen » Mon Jul 07, 2008 9:11 am
I'm not saying they're not needed. I suspect it's to warm the oil up to reduce drag in the gearbox as well as cool it down should it get hotter than the water.
For my requirements, today, which involves a leaking pipe, blanking the feeds is the best option.
However, the stealer was singularly unhelpful this morning. I don't own a b7 S4 so he can't find the plugs for me cos the computer won't tell him.
:roll:
spen
Post by spen » Mon Jul 07, 2008 1:32 pm
WOW. Camberley Audi called me back! The thread on the banjo bolts is M16x1.5.
VAG blanking plugs are £4.62.
Speedflow M16x1.5 blanking plugs are a bit cheaper - http://www.speedflowshop.co.uk/m16-x-15 ... -850-p.asp
aposegil
Re: RE: Re: I hate cars..... One thing after another...
Post by aposegil » Wed Jul 09, 2008 1:32 pm
dummi wrote:a6's don't have one and are ok, safe bet is trig's pipe solution
but musty A6 is running rs4 box.
in my car all i have done is cut the pipes and looped them back connect them together with some high pressure rubber hose you can see it coming in under the gearbox mount
alex
electric van for work
a4 v6 3.0 vortex sports for her
sold B5 passat 2.7T rs4/rs6 hybrid 477.17 bhp/471.98 lbs (483ps/640nm)
ZX9R sold replaced by hayabusa just because
Corrado vr6 turbo for fun
musty1
RE: Re: RE: Re: I hate cars..... One thing after another...
Post by musty1 » Wed Jul 09, 2008 3:41 pm
AHHHHHHHHHHHH I see the engine is out lets put some ko4's on lol
spen
Post by spen » Wed Jul 09, 2008 8:48 pm
Right I now have blanking plugs. I can take the leaking pipe off and quickly bung the gearbox. Then I can either loop the pipes together with a bit of hose as suggested, or I can leave the blankinig plugs in and see what happens. I think it'll be fine. No one in their right mind would design a 'box which used a pump with an external pipe as the only vent for the pressure. I hope....
what I really want to know is how Alex got my engine crane out of my garage without me knowing.... :)
Users browsing this forum: No registered users and 113 guests
