Does anyone know if the ecu connectors are the same LHD/RHD
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
smurfbus
Post by smurfbus » Thu Jul 03, 2008 4:42 am
The RHD engine harness is longer because it goes from left to the right and in LHD the ecu is on the left side. Longer harness could be even better by routing it away from heat but its the ecu connectors that might give some trouble?
TIA
flashyg
RE: Does anyone know if the ecu connectors are the same LHD/
Post by flashyg » Thu Jul 03, 2008 9:32 am
Think the connectors are the same.
I expect you are referring to the plugs that plug into the back of the ecu, if so yes the same. basically same ecu for lhd or rhd.
G
smurfbus
Post by smurfbus » Thu Jul 03, 2008 9:50 am
Ecu side connectors 81 and 40 pins. Thanks
tdiquattro
Post by tdiquattro » Thu Jul 03, 2008 5:01 pm
They are the same for Euro cars, but different on the USA cars.
Nige'
2000 silver S4 Saloon
smurfbus
Post by smurfbus » Thu Jul 03, 2008 6:31 pm
Yep. RAM said he had to cut some notch out of the ecu to fit a US harness
smurfbus
Post by smurfbus » Thu Jul 03, 2008 8:01 pm
Are the 2 extra rear O2 connectors with prefacelift ecu just dead or do I have to do somethinkg to the ecu if I use facelift loom?
