The RHD engine harness is longer because it goes from left to the right and in LHD the ecu is on the left side. Longer harness could be even better by routing it away from heat but its the ecu connectors that might give some trouble?
TIA
Does anyone know if the ecu connectors are the same LHD/RHD
RE: Does anyone know if the ecu connectors are the same LHD/
Think the connectors are the same.
I expect you are referring to the plugs that plug into the back of the ecu, if so yes the same. basically same ecu for lhd or rhd.
G
G
Ecu side connectors 81 and 40 pins. Thanks
- tdiquattro
They are the same for Euro cars, but different on the USA cars.
Nige'
2000 silver S4 Saloon
Yep. RAM said he had to cut some notch out of the ecu to fit a US harness
Are the 2 extra rear O2 connectors with prefacelift ecu just dead or do I have to do somethinkg to the ecu if I use facelift loom?
Users browsing this forum: No registered users and 97 guests
