yep, just tap into the positive feed to the light behind the vent wheel (on a facelift) works a treat, my omori matches the dash brightness exactly, and adjusts with the dash.Stigter wrote:Its that how you have the gauge lights powered tdiquattro? Is it really that simple as tapping onto the feed there?
The best way in is through the ecu waterproof housing, there is a rubber unused way in below the main ecu to engine cable entry, cut and then re-seal with silicone.
