B7 Brakes
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
B7 Brakes
Post by h8cak » Sun May 18, 2008 12:12 am
Do rear RS4 B7 brakes fit on to the B5 S4?
Wide Body S4
andrewneaves
Post by andrewneaves » Sun May 18, 2008 9:14 am
Yes they do fit. I have them on my (facelift) S4
See Brooner's write up on fitting front and rear B7 setup:-
http://www.rs246.com/index.php?name=PNp ... ic&t=53686
You need : -
RS4 (B7) rear calipers
RS4 (B7) caliper mounts
RS4 (B7) rear pads
RS4 (B7) brake lines
RS4 (B7) mounting bolts
The suspension legs also need to be drilled because the mounting bolts are larger tho' positioned the same.
It's a really worthwhile mod. If you have RS4 or RS6 setup at the front having the rear's uprated dramatically improves stablility under braking.
h8cak
Post by h8cak » Mon Jun 02, 2008 11:35 pm
It says you need caliper mounts? Does it mean carriers not caliper?
Wide Body S4
s4woody
Post by s4woody » Mon Jun 02, 2008 11:38 pm
caliper carriers is caliper mounts...
GARTH ROAD MOT CENTRE LTD
020 83353032
h8cak
Post by h8cak » Mon Jun 02, 2008 11:46 pm
Do these not come with the calipers?
Wide Body S4
