RS4 FRONT BRAKE CONVERSION.
Hi guys.
Just want to know if this conversion, fitting RS4 (B5) front discs and calipers is any good, or worth while?
Do you notice a big difference when fitted?
CHEERS.
CHEERS.
RE: RS4 FRONT BRAKE CONVERSION.
Ive done it and it makes a huge difference compaired to the standard S4 set up. HTH
Wide Body S4
One of the best mods you can do , Also the best value for money brake upgrade about.
Unit 20
0151 3366888
0151 3366888
If your going to upgrade your brakes go with stoptechs. )I havent personally had them on my car but i was a couple buddies with two S4s did a compare and contrast on the Stoptechs against the porschs 996 brakes on an S4 and the stoptechs had better stopping.
2001 Stage 2+ S4
GIAC Software
AWE
Clutchmasters
Stasis
Piggies
Hyperboost
FMIC
RS6s or GTs coming soon
GIAC Software
AWE
Clutchmasters
Stasis
Piggies
Hyperboost
FMIC
Re: RE: RS4 FRONT BRAKE CONVERSION.
PLUS Stoptechs fit under Std wheels - RS4's require 18" wheels at additional expense if you hadn't already changed them.2001S4ICS wrote:If your going to upgrade your brakes go with stoptechs. )I havent personally had them on my car but i was a couple buddies with two S4s did a compare and contrast on the Stoptechs against the porschs 996 brakes on an S4 and the stoptechs had better stopping.
RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
i might be interesteed in this "Stoptechs" mod myself, as would like to keep the original 17" avus wheels.
anyone got the details for Stoptechs ??
ta
ta
c5 RS6 plus in silver
They are a straight fit on the s4 , not sure about space under the 17in wheels .
Unit 20
0151 3366888
0151 3366888
ive got a pair of front RS4 capilpers collecting dust if anyone wants them?
Re: RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Just won some RS4 front brakes on ebay.grizz wrote:They are a straight fit on the s4 , not sure about space under the 17in wheels .
What to fit some braided front brake hoses. Does anyone know which ones to buy? S4 saloons or A4 Quattro Est/ RS4. Just need the fronts. Am running on 19" RS6 rep. Thanks in advance.
RE: Re: RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Those will not fit with the 17" wheels. I have tried it with a stock S4 wheel, and it would need at least 2 mm more space to the caliper.
Ahhh, that was you ADYS4FKU.... i was watching them too
Re: RE: Re: RE: Re: RE: RS4 FRONT BRAKE CONVERSION.
Ha ye. That was me.AdamS4 wrote:Ahhh, that was you ADYS4FKU.... i was watching them too
The RS4 lines are already braided so I have been told and the RS4 brakes are good upgrade (well they were for me as I upgraded from 1.8T brakes).
Users browsing this forum: Google Adsense [Bot] and 65 guests
