look athe bore picture and look at that nice big crack down the bore - no way anything is getting rebuilt on that engine.rolskii wrote:be good to look at yr oil pick up strainer ... see if its picked up anything to block or reduce oil flow/cause the lobes to wear prematurely also ....
(I got crank/rods pistons if needed..? couple heads too..)
Warning....check your cam lobes..
http://www.MRCtuning.com
for whatever reason that cam has started to wear first and led to that damage. It is very unusual for one lobe to wear with no signs of the others starting to wear - so not the usual case of an unloved engine.
i would say crap cam material or flaw
The cams are not usually checked unless you have a ticking, a misfire, or have leaking camcover gaskets... I usually look inside the filler cap and see one lobe - doesn't really help if you have buzzards issue though. It is also wise to check the oil pick, the turbo oil supplies, the play on the turbo shafts.... up but it is just not somehitng that is done on a regular basis otherwise ewvery inspection is a lot of money.
- Top Gear
- quattrokid1
- Top Gear
after seeing this I think I'll walk tomorrow!!
that is one hell of a mess there
hope your back up and running soonest
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
u edited out my postDoug_S2 wrote:look athe bore picture and look at that nice big crack down the bore - no way anything is getting rebuilt on that engine.rolskii wrote:be good to look at yr oil pick up strainer ... see if its picked up anything to block or reduce oil flow/cause the lobes to wear prematurely also ....
never intended for the pictured lump ...rolskii wrote:.. nor a cracked bore ......
..... probably get £30 a block next door at the scrappy Doug ...?
happy dayz .... party ....
Users browsing this forum: No registered users and 26 guests
