Modding an RS4 bumper to fit an S4?
I have just managed to get my hands on an RS4 Front bumper. What is required to get it to fit my S4? Any help would be appreciated.
Wide Body S4
RE: Modding an RS4 bumper to fit an S4?
The sides are too wide, you have tho "shrink" those somehow.
Also the bumper supports have to be little longer.
Here is my version of it
http://valitalo.org/rs4_bumper.htm
Nice job okkim .....is that a metal support fabricated to replace that nasty formed plastic support...... or is it decieving and that is the plastic piece re-formed ....
on moulding it - I started to do mine in a very similiar way, about 2yrs ago ..... rain come - sat in the shed since ..... one day it will get fitted ..
happy dayz .... party ....
That metal support is there for supporting the bumper to be in right formation. The plastic was also heated and molded. Then the metal support was glued to the bumper.
I just wanted to be sure that it won't change it's shape in the sun or cold. And it didn't even when I cracked the whole bumper in the accident!
Those were the only survived parts
bummer what a shame, i feel for you bud
S4 Crazy Horse. Ringsticker & MRC black magic.
tartan_rob
CliveH has done this I believe. Might be worth PM'ing him.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Blue_Thunder
- Top Gear
I've got a feeling Clive's was fitted without having to be reshaped as such, think the brackets held his in flush with the arches.
Re: RE: Modding an RS4 bumper to fit an S4?
Was it 15mm sq. tube ...? looks good... already started forming with heat and cuts .... but a loooong time ago ...okkim wrote:That metal support is there for supporting the bumper to be in right formation. The plastic was also heated and molded. Then the metal support was glued to the bumper.
nicely reshaped by the way ... care to enlighten us ...
RE: Re: RE: Modding an RS4 bumper to fit an S4?
So do u need to extend the bumper supports?
Wide Body S4
Re: RE: Re: RE: Modding an RS4 bumper to fit an S4?
You can bodge it by packing out the s4 units .... I got proper ones for the job though .... u need about 15mm extension .... i think ...?h8cak wrote:So do u need to extend the bumper supports?
RE: Re: RE: Re: RE: Modding an RS4 bumper to fit an S4?
S4TAN had his done by Greg Howell at Southam Bodies....great job too
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
So can i just buy some Rs4 supports? Are they a direct swap?
Wide Body S4
Yes you can swap to the RS4 supports, no problem.
Yes I didn't got a single scratch, but almost drowned...! Those are safe cars... My widebody project started there.nicely reshaped by the way ... care to enlighten us ...walked away from it ok ..?
- shineydave
when we did Clives we used the RS4 mounts and packed them slightly at the top to angle them a bit to allow the sides of the bumper to line up parrallel to the line of the wing. it seems the modding is to prevent the underside of the bumper appearing warped, unless you're very pedantic it's hardly noticable and probably not worth the effort
Does anything need to be done to the side mounts? and does anyone have the part numbers for the rs4 mounts i need to buy?
Wide Body S4
Users browsing this forum: No registered users and 134 guests
