rs4 downpipes or gutted s4?
hi guys, was thinking about getting rs4 downpipes but cant be arsed with making link pipes and fukin about with clamps so was just for guttin my standard s4 ones.
wont be taking the car to stage 3 so is there any point ?
how much would you expect to pay for rs4 dps? (second hand)
RE: rs4 downpipes or gutted s4?
oh forgot to mention that a full 3" cat back vibrant system will be goin on at the same time
- 5th Gear
theres some rs4 dps on ebay at the moment with gutted precats and no reserve...
665 bhp + 586 lbft...
Deffo go for gutted rs4 dps and get an exhaust system that has the same diameter! S4 main cats 400 cpi and the rs4's are 200 cpi like the milltek dp's! Cheap and effective option.
Dave.
White MK2 Golf.. Slightly modified
All I'll say is this job is massively labour intensive, what down pipes you fit makes no difference (other than mating it to the rest of the exhaust), just make sure you are happy as you dont want to have to repeat it.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
I shall be DIY'ing my RS4 downpipes soon.... will be posting a guide and piccys
Then i will fit the rest of the RS4 system
Good luck!
Re: RE: rs4 downpipes or gutted s4?
jimbo1234567 wrote:theres some rs4 dps on ebay at the moment with gutted precats and no reserve...
I could not find this... I saw some go really cheap a while back
Darren
- 5th Gear
RE: Re: RE: rs4 downpipes or gutted s4?
the listing finished yesterday. bigandyw bought them for his rs4 , maybe his std rs4 dps will be up for grabs?. see his exhaust posting in the classifieds.
just put rs4 pipes on mine with no precats, running a 3" miltek system, the link pipes are only 2 straight bits of pipes 63mm o/d if i remember correctly, this pipe slotted over downpipes and inside exhaust nicely. just welded up spare lambda holes, all done in 5 hours including removing pre cats.
Re: RE: Re: RE: rs4 downpipes or gutted s4?
was this done on a ramp?tom_rallye wrote:just put rs4 pipes on mine with no precats, running a 3" miltek system, the link pipes are only 2 straight bits of pipes 63mm o/d if i remember correctly, this pipe slotted over downpipes and inside exhaust nicely. just welded up spare lambda holes, all done in 5 hours including removing pre cats.
what did you have to remove?
Darren
RE: Re: RE: Re: RE: rs4 downpipes or gutted s4?
yeah done on a ramp, exhaust, dts to drop rear of the subframe, g/box mounts, heatshields, one of the egt"s disconnet the lambda plugs, bit of fiddling and swearing and out they fall.
Users browsing this forum: No registered users and 46 guests
