quick tech question
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
tom_rallye
quick tech question
Post by tom_rallye » Mon Aug 20, 2007 8:30 pm
h, new owner of an s4 and too this forum. had an intermittant boost prob for the last couple of weeks, plugged it into the scanner at work and needs 2 egt sensors, also had both banks running lean, would this be caused by egt's or something else?
thanks for the help
cheers tom
GrahamS4
RE: quick tech question
Post by GrahamS4 » Mon Aug 20, 2007 8:41 pm
Someone with some first hand know how will surely answer soon, but I am sure I have read that a faulty MAF can cause the car to run lean and if prolonged can cause EGT sensor failure.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
s4yogi
Post by s4yogi » Mon Aug 20, 2007 8:51 pm
Yea I agree both banks running lean is usually Maf and will have killed the EGTs over a long period of time
Harper--D
Post by Harper--D » Mon Aug 20, 2007 10:56 pm
So basically you need to replace maf and egt sensors!!
Dave.
White MK2 Golf.. Slightly modified :D
KayGee
Post by KayGee » Tue Aug 21, 2007 8:18 am
Sounds like two or three problems to me. MAF/EGTs shouldn't cause intermittent boost. A better description of the symptoms would be usefull as would a vagcom log.
yorkie
Post by yorkie » Tue Aug 21, 2007 6:37 pm
A shot maf will cause the egt's to fail but the only two cars I have logged the fault of failed egt's on were both running about 50% boost permanently not intermittent.
You won't get a fault code for the maf itself if it is still talking to the ecu, just low airflow readings.
p.s. from your id can I gather that you own or owned a Rallye Golf?
Sold mine a year ago to move up the ladder of money pits!
tom_rallye
Post by tom_rallye » Tue Aug 21, 2007 9:34 pm
thanks for the help guys, ordered new egt's and airflow meter and got some new dv's and samco hoses whilst at it. Think i'll have the pre cats out next week and map it, how much boost are you guys running safely?
cheers tom
GrahamS4
Post by GrahamS4 » Wed Aug 22, 2007 7:06 am
My boost on a mapped S4 with stock K03 turbos is 1.2bar peak dropping to 0.8 at high revs probably tailing further at the redline (dyno plot didn't run to full rpm so not sure).
HK-Steve
Post by HK-Steve » Wed Aug 22, 2007 2:44 pm
Does Vag-Com tell you that the EGT's have died??
From memory I can see a reading or 0.3k ohm and 0.6k ohm or something like that.
I ask as I had a bad MAF for 2 months before replacement,
Had lean codes on both banks.
Car pulls like a train, but I have not been logging long enough to get any EGT temps over 750'c
Appreciate your comments
Steve
yorkie
Post by yorkie » Wed Aug 22, 2007 6:35 pm
Yes, either "implausible signal" or "short to ground" are the usual faults listed.
I should know since I seem to be getting one of them weekly at the moment.
Users browsing this forum: No registered users and 65 guests
