Correct offset? Replica RS4 9 spoke 18's onto a B5 S4
The RS4 18" 9 spoke replicas I was about to buy are available in both ET35 and ET45. The ebay company selling them seemed unsure as to which was correct for my 99 S4
Sorry, I know this info has been posted previously I just cant find it. Does anyone know for sure?
RE: Correct offset? Replica RS4 9 spoke 18
How wide are they (Standard spec is 7,5" x 17" ET 45)?
S4B5 Avant
They are 8J wideMCB wrote:How wide are they (Standard spec is 7,5" x 17" ET 45)?
1999 Kingfisher blue S4 lightly fettled.
Don't have an answer however you could check yourself, if you buy ET 45 they will be .25"/6mm closer to the suspension upright. If this is tight you could always buy 5mm spacers - more £/hassle though, perhaps someone will have the answer for you soon.
S4B5 Avant
Re: Correct offset? Replica RS4 9 spoke 18's onto a B5 S4
ET35 no spacers required.StuH wrote:The RS4 18" 9 spoke replicas I was about to buy are available in both ET35 and ET45. The ebay company selling them seemed unsure as to which was correct for my 99 S4
RE: Re: Correct offset? Replica RS4 9 spoke 18
Definately 35. Audi fitted me some original 18" 9 spokes with a 43ET and the car wouldn't move off the ramps due to the callipers stuck hard against the inside of the spokes.
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
Running ET35 replica Nouvolaris here. Anymore and they would be outside of the wheel arch I would say.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
Thats good enough for me guys. ET35 it is then! Thanks for the help. PS Iv'e just bought a boost leak tester , i'll be done with it in a week or so , if any of you suspect a boost leek , let me know and ill mail it to you !
Be aware that some of the castings on the replica's will still hit the standard front brakes even at 35mm offset. Mine are 33mm and would have hit with new discs and pads. Not a problem with B5 RS4 brakes though...
Mark
Re: RE: Re: Correct offset? Replica RS4 9 spoke 18
Too true. My ET 35 18" RS4 B7 reps also hit the standard callipers with new pads, yet they clear the RS4 B7 big brake set-up!MarkB wrote:Be aware that some of the castings on the replica's will still hit the standard front brakes even at 35mm offset. Mine are 33mm and would have hit with new discs and pads. Not a problem with B5 RS4 brakes though...
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
bought and fitted
I received my 18"/8J rs4 replicas with there 225/40 goodyear F1 GSD3 wheels and fitted them yesterday, the clearance on the front brakes is tight 2mm (the pads are 90% new) but they went on fine!
They came with new studs perfectly balanced and a free looking nut set . and the centers are the raised embossed ones rather than the stickers.
£620 from http://stores.ebay.co.uk/AUTOSPORT-Carstyling. it wasnt a standard package but i asked and it was no problem for them to source the goodyears.
Despite only having 50 miles on them they are already grippier than my Walani's - so im hopeful that when they are scrubbed they will perform well. The side walls are definately stiffer than the no name tyres though as low spped ride is worse on broken surfaces.
RE: bought and fitted
The ET35's on mine are a bit close too - noticed this before, but yesterday to cure my squeeky brakes I put copper grease on the backs of the pads - put the wheels back on and they were jammed hard against the caliper.
A press of the brakes pulled the calipers back in and all was well. I'm thinking of putting some 5mm spacers on, as I'm not too keen on this situation.
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up
Users browsing this forum: No registered users and 39 guests
