I have a boost gauge fitted as per the AW giude, it reads 17 psi boost when at WOT but lately I dont think the car is boosting properly, no rush of torque etc.
Could I have a boost leak and still show all Ok on the gauge?
Daz
Boost Gauge v Actual Boost
RE: Boost Gauge v Actual Boost
Depends how bad the leak is. The turbo's will just work that bit harder to still give you the requested boost, until they get to the point they can't supply enough air. This is normaly soon before they fall apart
Mark
Where did you take the feed from - the fuel pressure regulator?
I would get your BPV's & MAF checked and (as MarkB alludes to) have your intake pressure tested.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Boost line feed is from back of the engine - cant remember exactly t pieced into a small pipe. MAF / 710n / bi pipe & f hose all replaced less than 6 months ago
Oh, & VAGCOM showed no faults ? What are the blocks to log for MAF & boost?
Engine module, block 003 for MAF & 115 for boost.What are the blocks to log for MAF & boost?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
