Well after getting the car fixed a couple of weeks ago, the turbos have tripped out again, on investigation today i found a pipe which didnt look to be sealed properly. I dont have VAG COM, It looks like I will have to get it from the states - any idea how long delivery time is?
Also is there anyway i can reset the ECU to delete the fault codes without it? I need to find out if this was the problem or not.
Daz
I have a boost gauge on order to help with diagnosis and to help check boost pressure.
Anyway to reset without vag com?
- mikeyquattro
- Top Gear
RE: Anyway to reset without vag com?
You can download a free trial for the vagcom site, but you'll still need a lead. Where abouts are you?
Someone on http://www.rs246.com/index.php?name=PNp ... ic&t=51359 could be of some help.
mike
mike
Tomorrow is another day
