Cheapest and best mod yet.
- SimonS4MTM
- Top Gear
Rang up the local Audi dealer (Portsmouth) to order the parts for this mod, the conversation went something like this:
Me: I'd like to order a new thermo switch, part no 021 919369.
Dealer: That's a part for a VW transporter, it will not fit an S4
Me: I'll take a chance, do you have the part in stock?
Dealer: It's a VW part we can't order it.
Cue call to VAG-Parts & mutual slagging of Audi's small mindedness
parts should be with me for fitting by weekend
Cheers,
Mark
Cheers,
Mark
Yes, just done mineIs this mod also for the RS4??
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
My advice is to get your battery tested also, mine went after about six weeks. Replaced with slightly higher capacity version been fine ever since. Top mod cheap and easy.
Does this mod make the cooling ALWAYS come on (ie after a short run, nothing warmed up yet) or just after a run when the car has got fully up to temperature?
Also, what noise does it make?
My car makes some noises when I switch it off after a run- not fans but I can hear a kind of whirring/hissing almost gurgling noise!
Runs an electric fan and water pump. Only runs if water temp exceeds 93oC. Which it can a few minutes after the engine is turned off due to heat built up.
HTH
Kevin
HTH
Kevin
WHen I shut my engine off I can hear a slightly squeaky sound as something stops moving under the bonnet - as if a belt is slipping or bearings are tight. I would say (and I haven't fully investigated yet) that it is coming from the driver's side of the engine towards the back of the engine. Does this sound familiar to anyone else?
Drivers side rear of the engine is where my hissing (bad description really) comes from.......I have no fear the noise is not normal.
Graham,
Mine does that as well always thought it was the Aircon....
