Wheel Alignment
Wheel Alignment
Hi,
I am based on Farnbrough, Hampshire. Anyone know of a good place that can do digital
4 wheel alignment in this area?
Cheers,
Jon
Cheers,
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
RE: Wheel Alignment
Same for me... but in the Southwest - Devon...
RE: Wheel Alignment
Was a thread on alignment places in tuning and mods forum about a month ago. Prices went from £120-£65 from what I remember.
Your local stealers may help you for a small fee of approx £270. AMD is near oxford if you willing to travel a small way but they say it can cost anything from £90 up to approx £260 depending on adjustments!!! These figures i've quoted are what i was told when i was shopping around for a decent 4 wheel alignment. I ended up going to stealth racing near Warwickshire and paying £90 all in. They didn't adjust the front camber as they said they couldn't do it as the arms aren't adjustable. After further research i found that the front camber can be adjusted by moving the sub frame, so maybe it would have been better for me if i had paid for one of the above to do the job, who knows......
Just have to keep an eye on tyre wear for now
Re: RE: Wheel Alignment
There is a good place in Newton Abbot, AMS which is down Brunel Road behind the train station, they have the right program for an S4 and were pretty cheap, £80 for 4 wheel check, adjustment to 1 rear and Nitrogen in the tyres.ZeroK66 wrote:Same for me... but in the Southwest - Devon...
Much better than the dodgy lot who did it in Fareham, they used the A4 program, left the adjustment on one of the rears loose and charged me £90.
Cheers,
Mark
RE: Re: RE: Wheel Alignment
ouch... thanks will pop down to Newton Abbot then - cheers!
