RS6 (C6) Alloy Rim Cleaning
Posted: Fri Oct 02, 2009 6:53 pm
by gdavison
I remember my other Audis always seemed to produce Brake dust that just does not clean .. All the Porsches I have had clear easily with Zymol Alloy Cleaner.. However the RS6 is as per the other Audi's .. Zymol Alloy Cleaner or AutoGlym Cleaner works I'd say about 90% ..however I get left with a few bits that just wont budge .. On My other Audis I used CarPlan Wonder Wheels which is pretty much pure acid.. so dont want to use that again
So what do folks use to clean the Alloys ?
RE: RS6 (C6) Alloy Rim Cleaning
Posted: Fri Oct 02, 2009 8:41 pm
by kwack
Bilberrys cleaner. try
www.cleanyourcar.co.uk
Followed off by some lovely pink wheel wax - once you done that teh brake dust just flies off with water
Posted: Mon Oct 05, 2009 2:00 pm
by technics100
2nd vote for bilberry.. really good stuff
Posted: Mon Oct 05, 2009 2:50 pm
by gdavison
Thanks all .. ordered and awaiting delivery
Posted: Mon Oct 05, 2009 3:32 pm
by david7m
What brand is the "lovely pink wheel wax"?
gdavison - let us know how you get on, as I use Wonder Wheels acid, but its running out....
Dave
Re: RE: RS6 (C6) Alloy Rim Cleaning
Posted: Mon Oct 05, 2009 3:45 pm
by gdavison
david7m wrote:What brand is the "lovely pink wheel wax"?
Poorboys Wheel Sealant
http://www.cleanyourcar.co.uk/wheels-an ... rod_9.html
Will do
Posted: Mon Oct 05, 2009 5:04 pm
by Jimmeh
Dave
Wonder Wheels is some of the strongest stuff out there - but, you're doing no favours to your wheels in using it (long term..)
I'd certainly consider the above (bilberry)
An alternative to the PB wheel wax is Chemical Guys' Wheel Guard. But my #1 for sealing wheels at the minute, is Chemical Guys JetSEAL109 (which too can be found on the CleanYourCar website.)
Jim
RE: Re: RE: RS6 (C6) Alloy Rim Cleaning
Posted: Tue Oct 06, 2009 10:11 am
by kwack
I use poorboys as above and teh brake dust just flies off with the hose and wheel brush. I rarely have to use bilberrys on them.
Once you visit that clean your car site you will end up getting more and more pruducts. The advise on teh forums is very good and the results speak for themselves. I can pretty do a full wash, cleanse and wax on my RS6 in about 2 hours and the results are great
Posted: Fri Oct 09, 2009 11:43 pm
by dibbs26
P21s wheel cleaner is excellent as an bi-yearly deep clean. It smells lke a rubbish tip and will remove any waxes etc on the wheel.
Once clean I tend to clay the wheels to get a perfect surface then I apply two coats of AG SRP and then two coats of AG EGP.
The above works a treat and is well worth the time to see those wheels shine !
Posted: Sun Oct 11, 2009 7:39 am
by xyber
Billberry wheel cleaner
protect with chemical guys jetseal109 and wheelguard, then I usual dia layer of collonite 476s as it's detergent and salt proof as it was originally designed for protecting boat hulls
Posted: Mon Oct 12, 2009 5:54 pm
by JayPlay
Bilberry is good but Epsuma Wheel Revolution wheel cleaner is better and goes alot further
