Mequires Clay Bars
Posted: Fri Aug 28, 2009 9:10 am
by ShaneyB
Been trying to remove a few tiny blemishes on my bonnet with this and having no luck at all.
Any advice? I'm following the instructions to the letter but nothing?
Thanks in advance.
RE: Mequires Clay Bars
Posted: Fri Aug 28, 2009 10:59 am
by stumpyrs4
What is ther blemish ? Have found with my Megs Clay Bar it's pretty good at taking off tar spots and the like...
Posted: Fri Aug 28, 2009 11:01 am
by ShaneyB
I've got a couple of tiny splashes of emulsion on the bonnet and they won't shift. I must be doing something wrong...
Posted: Fri Aug 28, 2009 11:50 am
by sonny
Iv heard that the Megs CB can be brittle, I have some but not used, I purchased the Sonis CB, no problems, have you tried soaking the area first, however with the emulsion it may obviously not come off, have you tried to use your finger nail lol
Posted: Fri Aug 28, 2009 12:06 pm
by ShaneyB
Yeah it picks off and emulsion is water based so I've been told hot water should do it??
Posted: Fri Aug 28, 2009 5:32 pm
by EssexBoyRacer
Which meg clay bar are you using? if its one of the kits from halfords type with the spray lube included they are extremely mild versions!
for something like what you are up against I would give a more agressive clay bar a try like poor boys / blackfire or even the more aggressive versions offered by Meg (but its expensive!)
Normally with an agressive clay bar you have to be wary of maring the paint but you should be ok on a VAG as the paint is known to be very hard.
You could also try something like Autosmart Tardis tar and glue remover to soften it up first, but make sure you wash it all off before using a clay bar as it melts the clay bar into bits!
You can get all this stuff from
www.polishedbliss.co.uk (good guides on there too!)
Posted: Sat Aug 29, 2009 11:36 am
by ShaneyB
Thank you guys
