Discount on PC7424 DAS kit from Autopia!
john_wintle
Post by john_wintle » Wed May 18, 2005 1:26 pm
Hi All!
I have a result from the people at Autopia in the States!!!!
If we can get 10 people in the GB on the DAS kit, then we can get a 20% discount on the item, which in this case is the Sonus DAS.
I already have 10 people so you guys can tag along on the end of this promotion. You can apply a promotional discount code when you make your individual purchase though a web link. The discount is applied to the goods before the carriage is added on.
Roughly this works out as follows:
  • DAS kit = £120 delivered
  • DAS kit + 1 spare Green + 1 spare Blue pad = £131 delivered
  • DAS kit + 2 spare Green + 2 spare Blue pad = £142 delivered
  1. Remember the exchange rate is about $1.90:£1 at the moment, so make use of it!
  2. It might be a good idea to get another green and blue foam pad, as these are the two that you will use most often
  3. Remember that this is a 110v system, so you WILL need a 110v transformer and an extension cable from Screwfix or a local electrical wholesaler
  4. I am going to post this on a couple of other forums as well, so we might not need 10 from here... :wink:
  5. The discount will be valid if product purchase is over $170 and includes at a minimum Sonus DAS Polisher Kit. Other products can be ordered with it
  6. Each persion will make their own individual order up and then apply the promotional code that I will supply
If anyone is interested, then please add to this thread in the normal manner, and I will let you have the appropriate info if interested.
Kind regards,
john.
John Wintle, 1273,
Sussex Regional Host, ClubGTI
http://www.clubgti-sussex.co.uk
RaceGlaze Reseller for VW
raceglaze@btinternet.com
