Dealer sticker, rear window
Posted: Fri Dec 14, 2012 3:02 pm
by redrsr
Does anyone know of a fool proof way of removing the dealer
Sticker from the rear window without damaging the heating wires??
Re: Dealer sticker, rear window
Posted: Fri Dec 14, 2012 3:55 pm
by gilford
Pull it off gently, use some of the mrs's nail polish remover to remove any residue.
There is a detailers product called "Tardis" which I've got, excellent at this, but not worth buying just for the one job.
Posted: Fri Dec 14, 2012 5:44 pm
by Batfinnk
If it's really hard to get off try heating with a hairdryer first to soften the adhesive.
Posted: Tue Dec 18, 2012 10:34 am
by Reflect Russ
Batfinnk wrote:If it's really hard to get off try heating with a hairdryer first to soften the adhesive.
^^^THIS^^^
Heating it up helps soften the adhesive and should pull most of it away with the sticker....if there is a lot of glue left behind then nip to halfords and try AG glue remover or similar product....as mentioned the best out there is Tardis but is expensive and only comes in 5ltrs.....
Posted: Tue Dec 18, 2012 11:03 am
by adsgreen
Check out a product called "Goo gone"
It's incredible at removing residue and gunk and you can buy very small bottles for peanuts.
Posted: Tue Dec 18, 2012 1:18 pm
by redrsr
Russ, think as the old gal requires your tender touch i'll leave it, I'll let you do it as part of the detail, be in touch
Posted: Tue Dec 18, 2012 4:38 pm
by Reflect Russ
Not a problem mate....seems a sensible choice....
