Newbie to RS6plus ownership
Posted: Thu Dec 08, 2011 11:14 pm
Just bought my first RS6...went for the plus model as it ticked all the right boxes.
I bought the car knowing it needed some minor TLC, but basically had a sound history and all the major complaints seemed to have been replaced - DRC, AutoBox, recent cam belt change inc tensioners, oil service, brakes/pads and tyres, 12mths mot. Wheels were refurbed 12mths ago. When checking the car over I noted the rocker cover gaskets seemed to be weaping a little - I had an M5 which did the same thing, and my local specialist did this - the bill was reasonable.
I took it to my specialist today because the Emissions Control lamp came on, and I was pretty sure I could smell oil in the cabin when applying a heavy right foot. The car also isn't as quick as I was hoping, but its difficult to bench mark as I have a 911 997 turbo as my toy car - and this is very very quick. Also if someone took my own car for a test drive and spanked its arse massively I'd be very annoyed - so its not the kind of thing you can really do on a test drive. Most things merely feel quick in comparison to my 911. I used to have e39 M5 (v8 model) as my family car - which was my first taster of a super saloon - over the years it was heavily modified - in the end - on a good day - it felt almost as quick as my 911 T. I was kind of hoping the Rs6 + with its 480BHP would be comparable to my former M5 - thus avoiding all the modifications and expense - instead I see some major costs on the horizon. Stripping some weight being one of them... There's at least half an adult condensed into the boot disguised as a battery..
Anyway enough of the waffle.. having looked in great detail on the ramps with my local specialist - we found some oil leaks.
The rocker cover I was aware of, however my specialist tells me the drivers side turbo seals have gone which is leaking into the intercoolers (which were saturated).
Given the miles and amount of work to get at them… I might as well replace both turbos … this is will be a major expense … has any one had this done? if so can somone suggest a bench mark cost for the turbos and labour?
Are there any uprated or bigger turbo’s to consider or a tuning company to do these and perhaps remap etc as a job lot cost - if so any thoughts on cost and who?
Seams daft to do this task and expense if there’s some comparable alternatives offering better performance and durability? Thoughts welcomed
I also found a light leak coming from within the flywheel to gearbox housing – any thought on what this might be. My specialist thinks its a seal but won't know which one until he takes out the gearbox. I also read that its good to replace the autobox oil regualarly - what oil is recommended amongst the owners... given their problems...
I also found that both front and rear wheels on the drivers side – have an excessive number of weights on the inner wall – suggesting that they might be bent – south yorkshire roads for you....
Drivers Car mats is also worn, along with steering wheel leather too – Audi are helping me source replacement individual pack items.
Not a great start to ownership, but I bought it for a price that was kind of reflective that there was some other reason the owner was wanting to part with it.
The rest of the car is v good. Any help welcomed...
