"Audio sources are muted
Posted: Mon Jan 26, 2009 10:08 pm
by andrewlowe
I would be very greatful if anyone has some ideas regarding the message I am now getting on the screen for the Radio/cd/tv/Nav. Audio sources are muted.
I had to do disconnect the battery and when I put in the code for the radio it all worked but I had no sound at all. When I go into the mode and try to switch audio all I get is a window with "Audio soucres are muted".
Any ideas would be very welcome!
RE: "Audio sources are muted
Posted: Sat Feb 07, 2009 1:35 pm
by lmdlmd
Hi - you have to go throught the menu system and select using the push button. Essentially when you have the message up (after selecting "radio") press menu and then you should have an option you can select, this should then clear the message. PM me if you want -I had the same issue
