When was your fuel filter last changed.
Posted: Sat Jan 19, 2008 8:18 pm
by boxerdogted
I have just carried out a full service on my car and also changed the fuel filter as Audi dont give a recomended change interval.
When i removed the filter the date stamp on it was 03/01 so i would say it is the original one from new as my car was registered 06/01 and has done 97k miles.
The filter is full of crap which will not help fuel flow and also make the pump struggle to supply.
I would recomend changing it anually as they only cost aprrox £10 depending where you get it from.
RE: When was your fuel filter last changed.
Posted: Sat Jan 19, 2008 8:53 pm
by s4woody
better than a pooper scooper ay ted..good call mate..and well worth the time and effort involved..
Posted: Sun Jan 20, 2008 12:35 am
by DavidT
My B4 S4 one was blocked at 80k miles. I reckon you are right, change at 60k miles, perhaps less on modified car.
Posted: Sun Jan 20, 2008 12:54 am
by s4woody
if you dont know the milage when it was last changed then have it changed as part of a service or a health check..
Posted: Sun Jan 20, 2008 12:55 am
by DavidT
Moved to the ownership forum by me as its a general interest thread
Posted: Sun Jan 20, 2008 3:07 am
by Virdee Autos
I changed mine at around 70k soon after I bought it, and mine looked like it had never been chnaged due to the condition of the filter, and the fuel that came out of it!
Bit more time consuming than a usual fuel filter change, hence probably why its not done, even when scheduled!
Posted: Sun Jan 20, 2008 5:31 pm
by boxerdogted
It is a bit fiddly to change but worth the effort and peace of mind that it has been done.
They also suffer from corrosion due to its location and can spring a leak which is the last thing you want.
Mine had been filtering for 97000 miles which equates to approx 4400 gallons of fuel at say 22MPG that is a lot of filtering.
It's also approx £22,000 worth of fuel which is frightening when you think about it but an awfull lot of fun.
Posted: Sun Jan 20, 2008 9:18 pm
by SimonC
Mine corroded-through in 2006 and was replaced under warranty. When I voiced my surprise to the dealer that they are never scheduled for replacement they agreed, saying that they see a lot of leaks due to corrosion.
Posted: Wed Jan 30, 2008 10:33 am
by TopBear
I've been thinking of changing this out as recently so handy that its come up.
Couple of related questions
Is there only a single filter in the whole fuel system?
What is the part number(s) of the filter(s)?
Are there any associated corroding washers\nuts\connectors that should be replaced at the same time?
Posted: Wed Jan 30, 2008 3:13 pm
by Blue_Thunder
Is the filter part integrated into the fuel pump?
Posted: Wed Jan 30, 2008 3:24 pm
by tartan_rob
It is not integrated but in line just after the pump. Accessible from below the car.
I changed the one on my B5 and after leaving it to dry for a few days, I could not blow through it.....perhaps the missus could (?!?!?) but not me....well worth doing, for the cost and hassle, I would do every 30k or so.
Posted: Wed Jan 30, 2008 3:34 pm
by ChipHazzard
Blue_Thunder wrote:Is the filter part integrated into the fuel pump?
No, It's a seperate unit located under the car just in front of the OSR wheel iirc, I need to get round to fitting mine at some point in the near future
Posted: Wed Jan 30, 2008 4:53 pm
by boxerdogted
You will need the new filter and four aluminium crush washers for the banjo bolts.
Posted: Sat Feb 02, 2008 11:32 pm
by quattrokid1
gettiing ours done tomorrow!!
found out today I was leaving a fuel slick behind me, sourced a new filter from Glasgow Audi for 13 quid plus vat...2 weeks ago it had 2 new rocker cover gaskets, air filter, oil filter and oil changed for 190 quid.
yes the fuel filter is in front of the osr wheel
Posted: Wed Feb 06, 2008 10:34 pm
by quattrokid1
turned out to be a badly corroded filter, apparently it should be done at service intervals but it looked like the original.
not bad for 107k miles...
the Ur probably has its original as well looking at it recently. That will be changed once its ready to roll again:)
