4 wheel alignment in South East
Posted: Mon Mar 12, 2007 6:47 pm
by QuantumJohn
Can anyone recommend somewhere in the South East for 4 wheel alignment?
Has anyone used Elite in Dagenham recently?
Last time I used them was over 4 years ago.
Otherwise QST?
Thanks,
John
RE: 4 wheel alignment in South East
Posted: Tue Mar 13, 2007 9:56 am
by ChipHazzard
John
Try www.alignmycar.co.uk although JD's just round the corner from me cant set the camber
Posted: Mon Mar 26, 2007 2:44 pm
by C9CRM
I was told to go to Truck Align in charlton by my local kwik fit
http://www.vipgroup.co.uk/Truck%20Align/index.html
They do lorrys but the kwik fit fitter said they will do cars!!
Chris
Posted: Mon Mar 26, 2007 3:39 pm
by david7m
After my recent event with getting mine done, I would advise Audi! I took it to two 'specialists' in the Milton Keynes/Bedford area, and they screwed it up....BIG time! Audi sorted, and was only £120 :thumbs:
Ring around a few Audi dealers first though, the price range is stupid!
Dave
Posted: Wed Mar 28, 2007 9:40 am
by RSVI
From Memory Camberley Audi take 2hrs doing it properly and charge i think £85ish.
Give them a ring
Posted: Wed Mar 28, 2007 10:52 am
by david7m
RSVI wrote:From Memory Camberley Audi take 2hrs doing it properly and charge i think £85ish.
Give them a ring
2 hours labour wouldn't be £85. Bedford Audi was £90 for a check, or £120 if adjustments were needed.
Dave
Posted: Wed Mar 28, 2007 1:33 pm
by JonnyX
Camberley Audi quote a minimum of two hours labour + vat (i.e. about 250)
Posted: Wed Mar 28, 2007 1:45 pm
by MarkB
JonnyX wrote:Camberley Audi quote a minimum of two hours labour + vat (i.e. about 250)
So where is good and also not a rip off near us then Jonny?
Posted: Wed Mar 28, 2007 2:21 pm
by RSVI
Just to confirm
Camberley will charge £80 inc VAT for 4 wheel alignment for an RS6 and this could take 2 hours.
Give them a ring and book your car in :D
Posted: Wed Mar 28, 2007 2:35 pm
by MarkB
I need some other bits doing so may just do that! Is Camberley Audi better than Guildford Audi for this type of work?
Posted: Wed Mar 28, 2007 3:11 pm
by RSVI
Is Guildford Good? When i asked Guildford a few months ago they told me it would be £200 ish and best to use someone else.
I would trust Camberley, ask to speak to Rob or Martin and tell them Adam told you they'd look after you. ;)
PS. this forum is read by Camberley, hence one reason of many, they WILL look after you.
Posted: Sun Apr 01, 2007 11:24 pm
by bogie
if you are near Elite then they are good for standard stuff....I have all my cars set up at Sinclaires, Gallows corner on the A12 nr Romford - they are a Lotus specialist but do all cars on a Hunter rig www.sinclairemotorsport.co.uk ...they will have all the stock settings in the database, but if you have a custom set-up for camber, castor, toe etc then they can cater for that....they even keep your custom settings in the database for when you go back.
