Leaking Windscreen Washer Water Bottle
Posted: Tue Jan 06, 2004 2:37 pm
by BlackShadow
How easy is it to replace the windscreen washer bottle on a Audi S4 2.7? The bottle, or maybe one of the pipes from it, is leaking. I pour 4.5 litres in the top and approx 4.0 litres runs on to the road. The annoying warning sign keeps coming on, and this weather you need to use the washers frequently and they've got not a lot in them.
I'm not super gifted in the spannering department, so if its difficult, I'll take it to the Audi garage.
Re: Leaking Windscreen Washer Water Bottle
Posted: Tue Jan 06, 2004 3:46 pm
by wazza
It has been spoken about before
here. [img]images/graemlins/thumb.gif[/img]
Posted: Tue Jan 06, 2004 6:32 pm
by BlackShadow
Many Thanks BiTurbo for guidance again. I'm quite impressed, this website is full of useful stuff.
Posted: Tue Jan 06, 2004 9:24 pm
by martian
Same thing happened to me but the water p***ed out from underneath the bumper- they had to remove the bumper and parktronic just to reconnect the hose (apparently) [img]images/graemlins/blush.gif[/img]
Audi Specialists, Burwell, Cambridge
Posted: Wed Jan 07, 2004 2:15 pm
by BlackShadow
Yeah, I had the inner wing off last night. It is not leaking from anywhere near the bottle or any of the connecting pipes. It is p***ing out from under the bumper. The guy at my local independent Audi garage said the pump often leaks and needs replacing, which requires taking off the front bumper/air dam thing. I shall be giving the car to them to sort that out, and my malfunctioning external heat sensor reading.
The garage concerned is Audi Specialists in Burwell, Cambs (
www.audi-specialists.co.uk). Anybody got any previous experience with servicing by them? Their hourly rate is less than official Audi dealers. Those chaps seems to charge a rather steeper rate. I phoned Bishop Stortford Audi, and I'm quite suprised that the guy managed not laugh when he announced that they charge 82 squid an hour [img]images/graemlins/jawdrop.gif[/img].
Re: Audi Specialists, Burwell, Cambridge
Posted: Wed Jan 07, 2004 9:47 pm
by Carps
Another common fault that can cause the bottle to empty is the hose on the headlamp washers comes off. This is due to the very high pressure at which they operate. I believe this can be checked and rectified without removing the bumper, so it may be worth a look at that first...
Posted: Wed Jan 07, 2004 11:28 pm
by BlackShadow
Any idea where to look in the front bumper or under the bonnet to find this hose on the headlamp washer?
Posted: Fri Jan 09, 2004 2:14 pm
by Dippy
Yeah, the active search mechanism (a.k.a. Biturbo) is particularly good [img]images/graemlins/grin.gif[/img]
I'd advise you to look on AudiWorld too. The forums are rather tedious (and purile) but there's some excellent technical info there. In particular (as I implied in that other thread), the washer bottle problem is as common as muck in the US so you might find some excellent guidance information on AW.
Posted: Fri Jan 09, 2004 2:16 pm
by wazza
Dave your fiver is in the post as we speak [img]images/graemlins/acclaim.gif[/img]
Posted: Wed Jan 21, 2004 10:36 pm
by martian
I've had a little 'dispute' with my dealer over the heat sensor issue. I know it's been discussed in other threads but it would be really handy if you could give me a clue to your particular symptoms, diagnosis and remedy.
Posted: Thu Feb 26, 2004 12:42 pm
by BlackShadow
Ahh, bit of a late response here, but I did get the outside temperature sensor repaired under (independent) warranty. Basically the sensor had come loose. The dealer said it might have been cut off by the fan? Anyway, it was remounted and now it works normal. "Normal" on a S4 seems to mean that moving along the road, the outside temperature reading is fine, but stop in traffic for a while and the outside temperature reading will rise. I guess this is to be expected, given the heat being generated by the engine. If you've got a big RS6, I guess this would mean more engine heat.
