Door Indicator in DIS
Posted: Sat Feb 20, 2016 7:54 am
by travs
C6 A6 owners, I have a funny thing - open the Drivers door and DIS displays the front passenger door open. Same for the other side. Fronts only, the tears are correct. Is this a "thing"? It's quite quaint so not bothered unless it's an indicator of something bigger. Anyone else had the same?
Re: Door Indicator in DIS
Posted: Mon Jun 13, 2016 8:49 am
by tartan_rob
This is not standard but I wonder if someone has been tinkering with VCDS? I saw this once on an A4 saloon when they set the car to be a cab. Not sure if that was an option on the A6 but worth checking.
Pretty sure it's not a wiring issue as it affects both sides....VCDS will pick them up.
