Tyre Pressue
Posted: Fri Dec 27, 2013 12:02 pm
by Swanee
Hi all, Im sorry is this has come up a million and one times but is there a definitive recommended tyre pressure for a B7 RS4 Cabriolet?
Im running at 35psi at all corners, only asking as I had 'low pressure' warning come on yesterday as I was driving back from Oxford so topped up the pressure to 35psi and after 10mins the warning went off. Is this usual?
Cheers,
Re: Tyre Pressue
Posted: Fri Dec 27, 2013 12:17 pm
by S4WON
theres loads of threads about this.... and i've tried a few different ones. broadly:
The front needs more pressure (it has the engine in it!)
people run anywhere from 33-40 it seems
I personally run whats on the door for my avant - which is 38 front & 35 rear on 235/35/19s (IIRC)
so if I were you, id check your door and based on your wheels, go with whatever they suggest - but always put a couple more PSI in the front.
Re: Tyre Pressue
Posted: Fri Dec 27, 2013 12:29 pm
by Swanee
Thanks S4WON, seems like there's no real definitive so I suppose I'll try a few different levels and see what's best.
Re: Tyre Pressue
Posted: Sun Jan 05, 2014 8:29 pm
by rocket1
on my avant im running 38 front and 35 rear too. when i first picked it up it had just had a full wheel refurb and they were all set to 50!
