cheeky urchinoliew wrote:N75s only cost a few 'squid'
tweak it haha
N75 valve - how does it work
- ChipHazzard
Re: RE: Re: RE: Re: RE: N75 valve - how does it work
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
RE: Re: RE: Re: RE: Re: RE: N75 valve - how does it work
groan-mongous mate!cheeky urchin
Deus ex machina
OK, the one I had in before was a ... 078906283B
Remember that was probably the stock N75 on the RS4 engine ....
Yep - i think that's the case.Remember that was probably the stock N75 on the RS4 engine ....
Does your new Q valve look any different to the stock B - or is it identical?
Deus ex machina
My Cod I've won 10 Squid!
Could put that towards having my Mullet trimmed, or a new Barbel for my weightlifting set or just pay of some of the balance on my Goldfish card.
Or could just take the old Trout out for a drink.
Now I'm Floundering..
Re: RE: Re: RE: Re: RE: Re: RE: N75 valve - how does it work
It is different, its like all back to front if that makes sense!S4TAN wrote:Does your new Q valve look any different to the stock B - or is it identical?
I will try to get a picture, but I lack a digital camera at the moment!
OH DAM!! I seem to have lost 0.1bar of boost while talking about this!! here we go again on the lost boost journey!
RE: Re: RE: Re: RE: Re: RE: Re: RE: N75 valve - how does it
MUST ... HAVE ... PICS!!!will try to get a picture
Deus ex machina
Can I have a go please?
Primary boost control is via the spring in the wastegate, pressure in the inlet manifold is fed to the WG, pushes against a diaphragm, compresses the spring which opens the valve, diverting ( or "wasting") the exhaust gasses away from the turbine. Without a wastegate the turbo would just give more and more boost untill it self destructs (more boost = more exhaust gases=more boost.. etc.). The Waste Gate Frequency Valve (N75) sits in this pressure line and diverts some of the pressure that would normally open the wastegate back to the face of the turbo thereby allowing more boost than the WG spring would normally allow. This is the secondary boost control done by the ECU.
Duty cycle is a strange thing, you'd think you would just adjust the size of the hole in the valve to modulate boost but they don't do it like this. (cos you would need a proportional valve which is continually adjustable, the N75 is a simple open or closed type valve) Instead they modulate the valve, opening and closing it rapidly. The duty cycle is the ratio between the open time and the closed time and this controls how much pressure is diverted away from the wastegate.
I'm not that keen on fishing these days, although I was once sacked from a band for going fishing instead of to rehearsals..
The MAP sensor measures up to 1.55 Bar, which is 5 Volt. You solder a Zener diode (4.7 volt) over the signal lines. This means the MAP will never measure more than around 1.3 Bar no matter what the boost is. You need a remap that requests more than 1.3 Bar tho!! Then you put a MBC in parallel to your N75, which enables you to adjust and run as much boost as you turbos can produce. The ECU works via airflow anyhow and will inject more fuel accordingly.S4TAN wrote:How do you clamp the MAP? I've seen the H version and know the connector socket is rotated but i reckon i've got enough slack in the lead to still plug in ...if you don't clamp your MAP
That's how a lot of yanks hombrew tune their cars.
But the best way is to get a decent remap !!! IMHO
So, with my new map, and on the basis that the MAP sensors can only read 1.55 bar, my max boost is worked out by the best the turbo can do ... ie, they are running at their physical max with the current actuators ?
Viper - I've just bought (and fitted) an N75 valve for the S2 (ABY) - it has a PN of 034906283K ... I reckon your Q34906283H was actually 034906283H (a "zero" not a "Q") ... the connector on the K version is rotated through 180deg .... had to do a bit of jiggery-pokery to get it fitted, but got it done.
Sourced it from vag-parts - they still do the H version (and a J version) but I went for the K as an experiment ...
The car feels GREAT running on this valve; really "perky" and instant response (also getting around 2-3psi more boost) ... Doug had a look and just tutted and grinned (but it was him who told me about doing this in the first place)...
If i blow my turbos then you can all laugh and say "told you so knobhead!" ...
Deus ex machina
Perhaps this'll spice things up a bit in here . . .
http://www.norfolkantiquesandart.co.uk/prawnography/
S4TAN wrote:Viper - I've just bought (and fitted) an N75 valve for the S2 (ABY) - it has a PN of 034906283K ... I reckon your Q34906283H was actually 034906283H (a "zero" not a "Q")
I knew I should have not left scool at 11
You know what you need ?? I boost controller!!S4TAN wrote: The car feels GREAT running on this valve; really "perky" and instant response (also getting around 2-3psi more boost) ... Doug had a look and just tutted and grinned (but it was him who told me about doing this in the first place)...![]()
I can set mine so it boosts to 1.6 bar for example, for most normal spirited driving, then if that FQ400 or quick bike makes and appearance, a little turn on the knob and hey presto, we have that extra boost on tap! Can't go wrong
