hi guys ii am from middle east i imported my s4 b5 about 3 years ago from USA ,its a s4 b5 2002 with 5 speed tiptronic transmission
now the transmission become bad , start getting gear ratio fault codes and limp mode
so now its the time to swap to manual transmission but the problem is i couldn't find any 6 speed 01E transmission in my country all what i got is two 01A transmissions one from 1.8 audi a4 b5 oem number is 01A301231G code PHH and the other one is from passat b5 v5 2.3 engine oem number is 01A301231H code PHH and the rear diff code CKK from audi a4 b5
so any one know the final gear ratio for these transmissions and which one will work with the rear diff CKK
and about the front axles the s4 comes with big inner and outer cv joints and the both 01A transmissions i got from the donor comes with small inner and outer cv joints
so what i should do can i swap the inner and outer cv joints to the s4 front shafts axles
Audi s4 b5 with 01A 5 speed transmission ?
Re: Audi s4 b5 with 01A 5 speed transmission ?
Where in GCC are you?
Users browsing this forum: No registered users and 26 guests
