A nightmare after one day of ownership
Re: A nightmare after one day of ownership
you would be hard pressed to hit the sump without the undertray being smashed,etc,and the lowest point of any b7 rs4 is the downpipe flexi-most of us have the furry flexis to prove it
during work,often garages use too much sealant or let debris fall into the engine-its picked up by the sump oil strainer which becomes choked reducing oil pressure-however you will be warned of that on the dash...
dont let them fob you off demand refund in full-get solicitor involved asap if they dont play ball
also inform them you hold them liable for all your running about costs and any other expenses
furthernmore the rs4 is not known for timing chain issues-they may well have left the original cause for the other work[ oil pick up perhaps] and merely been repairing the outcome-is sounds like it has dropped a valve previously-low oil pressure-timing chain tensioner goes slack-engine valves touch pistons
if they have already stripped it any inspection is tainted in any case
+1
Get a full refund + expenses, they will fold if you get a solicitor involved. Most solicitors offer the 1st consultation for free.
I once had a gerabox rebuild that went pop after some miles, I took it off, put in a box, walked into the garage with 4 big mates, slammed it on the counter and told the owner to immediately refund me. Funnily enough he did just that. Some people just need a little push.
Totally agree with everything said so far. I don't even think you should be getting an independent inspection to prove anything, go straight to the solicitor and Trading Standards as clearly this car was not fit for purpose, and you cannot be liable for internal engine failure within 70 miles. As Arthur.d states, I wouldn't have expected an RS4 engine to need that sort of work at that mileage without a previous fault. Perhaps this car has been in an accident. Hopefully you can get this sorted.
Hi, I feel very sorry for your loss I can understand how you might feel.
If I may make a few points ,I would say the engine failure is due to faulty workman ship, ie blocked or damaged oil strainer pipe and they may well of used instant gasket which has blocked the filter on the oil pump.
I would say a dent in the sump can no way affect the oil lubrication system.
I would say you are due to a full refund due to the car not being fit for purpose.
Also be very careful that this does not drag on for a long time and ends up costing you a lot of money if you can possibly help it.
Good luck.
Jim
Good luck.
Jim
just to update, been back to inspect it, there is a dent on the sump that could correspond with the engine being on a jack or another surface under its own weight. They are saying i have hit something which has then dislodged a black plastic ring which then got sucked up into the oil pickup. I can 100% say i did not hit anything. Their strongest argument that the guy who had the engine out can remember there was no damage to the sump and that i drove the car 70 miles and before i had it it was 'thoroughly' road tested by a few of them... surely if this is just internal failure caused by normal driving, I am not liable.
RS4 sump uses liquid(instant) gasket from factory by the way. I know kinda crazy. The question is, did they use a correct one?jimi wrote:Hi, I feel very sorry for your loss I can understand how you might feel.
Good luck.
Jim
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Dude that sucks! I feel you pain mate! But I strongly believe you have a winning case here!dmc11 wrote:just to update, been back to inspect it, there is a dent on the sump that could correspond with the engine being on a jack or another surface under its own weight. They are saying i have hit something which has then dislodged a black plastic ring which then got sucked up into the oil pickup. I can 100% say i did not hit anything. Their strongest argument that the guy who had the engine out can remember there was no damage to the sump and that i drove the car 70 miles and before i had it it was 'thoroughly' road tested by a few of them... surely if this is just internal failure caused by normal driving, I am not liable.
Like others said, you can’t damage sump like that with out splitting it or at least ripping the plastic guard to <beep>! The sump has baffles inside to prevent from oil starvation. Like I mentioned before, they may have used wrong instant gasket compound. (Rs4 uses specialised type made in Germany. I know this because I need to change mine and bought it already after hours of research was amazed at what they used from factory)
Maybe send that for examination. Also need pictures of the inside of the sump.
But like others said, Get solicitor involved.!! Good luck
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
the very fact that they have been pissing about with the engine sets alarm bells ringing-how can they possibly try and say its somebody elses fault...
could have been handled roughly during removal/refitting -damaging sump as well as a hundred other things
Seems suspicious all the front suspension was changed at the same time as all the engine work? Caused by an accident?
Is there any evidence of damage underneath?
Good luck with the resolution you deserve.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
yeah i couldn't agree more, their main argument is that the guy who did the work inspected it after and he is certain the sump had no damage. I've had a mechanic come to look and said it could have easily been missed
no obvious signs of accident damage underneath. I know the drc has issues though so think suspension is related to that. But their is no marks on the flexis either so suggest anything hanging in line with or lower than the sump was also damaged
- Surrey Sam
Couple of things.
Have you checked the engine number to see if it's the original? Could be a replacement thrown in roughly or transported on a pallet that's caused the damage.
Do they have any receipts supporting all the components which are alleged to have been replaced?
As mentioned before, it all sounds rather dodgy. So get legal advice and remain factual with the dealer whilst trying to resolve it.
had legal advice, as im rejecting the car and the dealer is refusing my rejection an independent assessment needs to carried out. The garage are unsurprisingly standing by their work and we are just butting heads
I wouldn't even be bothered about whatever work was done, the bottom line is you bought a car from a trader with 12 months warranty, and the engine has lasted 1 day. That is clearly not fit for purpose so you are well within your rights to demand a refund.
i couldn't agree more, wish i had paid by credit card so i could do a charge back. the claim is i have damaged the car in my ownership and they are in no way liable.He has compared it to driving into a lamp post ! If this does go to court i have plenty of evidence and also now have plenty of opinions from actual rs4 owners, not just a garage claiming they know the car !
