RS2 cambelt change
RS2 cambelt change
Can anyone advise on how I can change the timing belt on my RS2? Thank you in advance for any assistance. Tom
Re: RS2 cambelt change
It's fairly straight forward once you get the front off as it's all facing you unlike the 1.8t cambelt.
I've not seen too many rs2s on here unless they are lurking in the undergrowth. I'd say Google it there must be a step by step.
When/ if you swap the water pump make sure the block is smooth and the rubber seal isn't brittle is some neat g13 for lube when tightening up as they can weep.
Try the S2 forum.
Many thanks. Tom
Send me your mail adress, and i will retur some photos of how it is done.
