Cruise Control not working.
The cruise control has stopped working on my 2006 RS4 Avant.It doesn`t activate when using the lever.
anyone got any ideas ???
Thanks in advance,Stevie.
Have a search for clutch switch, should sort it. Easy DIY.
RS4 Avant - Misano Red
Re: Cruise Control not working.
As above - Your start button wont be working properly either.stevie mcauley wrote:The cruise control has stopped working on my 2006 RS4 Avant.It doesn`t activate when using the lever.
Thanks lads,
Offshore at the moment so I`ll have a look when i get home.Is it an easy fix?
There is a guide somewhere on here but can't seem to find it, sure someone will be along to help.
Some info here http://forum.rs246.com/viewtopic.php?t=98405
Thanks again lads.
Mine did that once, and it turned out to be a faulty brake switch.
check out the possibilities first!
I've finally got my head together but now my body is falling apart!
Hi all, changed the Clutch Switch and normal service has resumed...going like a dream now.
Thanks to everybody for their advice and help golks.
Stevie.
Stevie.
....folks..
Users browsing this forum: No registered users and 39 guests
