Rear brake discs
Posted: Tue Oct 30, 2012 10:26 am
by BillTheButcher
I've been looking around the web for parts suppliers and there seem to be two types of rear brake disc listed for the RS6.
The first is this one:
http://www.gsfcarparts.com/603vg0700
£252.00.
The second is this one:
http://www.gsfcarparts.com/603vg0022
£23.40.
Now I can see from the info that the second one has completely different dimensions and it's solid rather than vented; it looks like it's not even suitable for the RS6. If that's true why do so many supplier sites list both when searching for discs for an RS6.
Re: Rear brake discs
Posted: Tue Oct 30, 2012 1:11 pm
by Mr V10
The disc in the second link isn't the right one, must be for another Audi model.
Posted: Tue Oct 30, 2012 1:15 pm
by BillTheButcher
Thanks Amar. That seems to be the case, even though I searched by registration.
Are there any alternatives to the OEM discs or are they as good as you can get?
Posted: Tue Oct 30, 2012 1:19 pm
by mik15
there's also Zimmerman, but the price is close to the OEM one...
Posted: Tue Oct 30, 2012 1:56 pm
by Mr V10
Check Euro Car Parts and use the SRS discount code.
Posted: Tue Oct 30, 2012 1:59 pm
by Nobby
Did you get some from ECP in the end Amar? I thought they had problems with stock etc..
Posted: Tue Oct 30, 2012 2:08 pm
by Mr V10
Nope, I went genuine Audi. Not going to go OE again.
Posted: Tue Oct 30, 2012 2:13 pm
by BillTheButcher
Amar wrote:Check Euro Car Parts and use the SRS discount code.
Nobby wrote:Did you get some from ECP in the end Amar? I thought they had problems with stock etc..
They're showing one of each pair of drilled and non-drilled in stock. Useful.
Cheers for the heads-up on the discount code Amar. Didn't know about that.
Posted: Tue Oct 30, 2012 9:35 pm
by Rob1977
Are you looking for plain or drilled? I might be able to help.
Posted: Tue Oct 30, 2012 9:53 pm
by BillTheButcher
Rob1977 wrote:Are you looking for plain or drilled? I might be able to help.
Hello Rob.
I try not to brake late or hard so plain would probably be more than adequate especially for the rears.
Unless anyone who knows more than I do can give me a reason why I should go for drilled...
Posted: Wed Oct 31, 2012 10:06 am
by Shoppinit
No, I prefer plain. The only reason you would put drilled on the rears is for aesthetics.
Posted: Wed Oct 31, 2012 10:07 am
by BillTheButcher
Shoppinit wrote:No, I prefer plain. The only reason you would put drilled on the rears is for aesthetics.
Thanks.
Would you put drilled on the fronts?
Posted: Wed Oct 31, 2012 10:23 am
by Shoppinit
No, I would prefer plains. But I don't have the choice with the C6 brakes.
Posted: Wed Oct 31, 2012 10:39 am
by BillTheButcher
Thanks.
I *think* I've got drilled fronts on the E55 but I really don't know. I haven't looked that closely.
I have no preference either way; as I said I try not to brake hard or late so I was thinking that the drilled ones would probably be wasted on me.
