Page 1 of 3
Worrying experience...
Posted: Sun Sep 30, 2012 6:29 pm
by chrisn6
Hi boys & girls,
On returning to my car today after parking it on a very slight upward incline (5 degrees?) the engine turned over without a hint of trying to fire. I tried maybe 7 or 8 times with a few lengthy attempts. The car had never failed to fire within a few seconds over the 20 months ownership. I called for breakdown assistance and after five minutes, decided to try again. It fired up immediately! I cancelled the recovery and drove home. Started perfectly a few hours later also. I hate intermittent problems like this. Anyone else experience the same issue? Of course I'm now worried this will happen again at any time. I did try activating and deactivating the alarm several times. No warnings on the dash. Could the slight incline have caused fuel starvation? Seems very unlikely.
Thanks in advance for any suggestions.
~Chris
Re: Worrying experience...
Posted: Sun Sep 30, 2012 6:36 pm
by Shoppinit
Maybe you've got a dodgy transponder transmitter / receiver ring (that interrogates the key transponder). Can happen. If it happens again try to see if the immobiliser warning light stays on.
Posted: Sun Sep 30, 2012 6:48 pm
by chrisn6
Shop. I did check the immobiliser warning and that went off each time. I think it started without me actually switching the alarm off/on. The keys were in the ignition and I thought, nothing to lose and 'bam', it sprang to life! Not looking forward to getting stranded soon...
~C
Posted: Wed Nov 07, 2012 6:38 pm
by chrisn6
Hey guys & girls,
Sorry to resurrect this thread, but after 5 weeks of trouble free starting, the same exact thing happened today. This time, after about 8 or 9 attempts at turning over without a hint of firing, and a wait of a further 3 or 4 minutes while I called up the breakdown service, I turned the key while on the phone and it sprang into life! So, it is no longer an isolated incident. The immobiliser light was not on during any of the attempts so it's unlikely to be that I would think.
Do any of you think it could be the fuel pump relay? Anything else that I should look at?
Thanks again for any help.
~Chris
Posted: Wed Nov 07, 2012 7:21 pm
by Simon T
Sounds like a job for MRC or Unit20 to me.
by bakustax
You sound like you might be an unlucky cu*t
Posted: Wed Nov 07, 2012 7:23 pm
by chrisn6
bakustax wrote:You sound like you might be an unlucky cu*t
Evidently, hahaha!! MRC and Unit 20 are too far away for me. Could be a job for Virdee...
~C
Posted: Wed Nov 07, 2012 8:27 pm
by chunky79
Now now backdoor, language like that and you will upset some users
Posted: Wed Nov 07, 2012 9:16 pm
by Shoppinit
Could be crank position sensor. Fairly common and will prevent the engine from firing.
Posted: Wed Nov 07, 2012 9:22 pm
by chunky79
Where are you based? Someone might be able to help out with
Vagcom.
Posted: Thu Nov 08, 2012 10:29 am
by chrisn6
Thanks for that
Shop. Is it worth replacing the Fuel pump relay just in case or is that unlikely? Chunky, I'm in Chiswick, London. I do have the free
Vagcom. Problem is, if it's all starting fine again, as it is now, will the
Vagcom show up the fault?
~C
Posted: Thu Nov 08, 2012 10:48 am
by rossi46
Admittedly not on an RS6, but I had very similar symptoms on another car (Volvo) ; Despite my local garage trying various things without success, I eventually insisted they replace the camshaft position sensor and that was 2 years ago .. the car has been fine ever since.
Sorry, can't help re the
Vagcom question
Posted: Thu Nov 08, 2012 10:55 am
by chrisn6
Thanks Rossi. Looks like I'd best drop it off to Virdee. Oh well...
~C
Posted: Thu Nov 08, 2012 12:25 pm
by chrisn6
Just wanted to say thank you to all, especially
Shop. I ran the
Vag Com Lite and it showed "Engine Speed Sensor (G28): no signal/communication - Intermittent". Guess I need a crank sensor! Anyone here know a cheap supplier?
Cheers,
~Chris
Posted: Thu Nov 08, 2012 12:31 pm
by chrisn6
Found this
http://www.ebay.co.uk/itm/Crankshaft-Se ... 4d05eac027
I'm sure it's much cheaper than from a stealer!
~C
