Passengers side electric switch trim removal???
Posted: Tue Jul 24, 2012 3:34 pm
by amanda1
Before I break anything........does this just pop out or is there more too it???
Re: Passengers side electric switch trim removal???
Posted: Tue Jul 24, 2012 3:42 pm
by imacool
amanda1 wrote:Before I break anything........does this just pop out or is there more too it???
What switch? I'll look in Work Shop manual, just tell me what switch do you want to remove (seat, window?).
Posted: Tue Jul 24, 2012 3:47 pm
by gingertoss
If its the window switch then there is a hole on the underside of the arm rest under the switch. Use the biggest allen key you can get in the hole and push the switch out gently.
Posted: Tue Jul 24, 2012 4:03 pm
by imacool
It took me ages to move the images and convert them to be viewable here, hope you appreciate the effort...
Vehicles with hole on underside
– Insert screwdriver -3- in hole.
– Use screwdriver -3- to press retaining tab -2- in direction of arrow -A-.
– Take out window regulator switch unit -1- in direction of arrow -B-.
- A70-0624.jpg (17.41 KiB) Viewed 1241 times
Vehicles with no hole on underside
– Mask door trim with adhesive tape -4-.
– Take out window regulator switch unit -1- in direction of arrow.
- A70-0178.jpg (18.06 KiB) Viewed 1241 times
All vehicles:
Press retaining tab -2- and pull off connector -1-.
- A70-0179.jpg (24.74 KiB) Viewed 1241 times
Posted: Tue Jul 24, 2012 4:12 pm
by amanda1
Yes sorry Tis the window switch.....it has been picked at by the bratzs but no one will admit to it aghhhhhh
Posted: Tue Jul 24, 2012 4:15 pm
by imacool
Check the underneath, there may be a hole, if not then the second picture applies.
Mind the work
Shop manual is written for left hand drive vehicles...
Posted: Tue Jul 24, 2012 4:52 pm
by amanda1
Thank you so much for the piccies
I have the hole so as soon as I feed the bratzs I will let you know how I get on!!!
Posted: Tue Jul 24, 2012 5:01 pm
by R8GXR
<beep>, thought mine were bad! keep an eye out for the vapour blasting pictures later.
Posted: Tue Jul 24, 2012 5:28 pm
by imacool
R8GXR wrote:<beep>, thought mine were bad! keep an eye out for the vapour blasting pictures later.
I can't wait...
Posted: Tue Jul 24, 2012 7:29 pm
by amanda1
Well that was painless enough .....except the old trim bit is now broken due to getting the window switch out but the new trim bit was only £7.54
so happy days!!!
Posted: Tue Jul 24, 2012 9:21 pm
by Shoppinit
Rub the remaining rubber off the door handle and it will look great with the new switch. This is what I did. It looks factory.
Posted: Wed Jul 25, 2012 11:49 am
by rosssavage
I did my mirror switch cover the other day and it looks so much better now.
Also did what
Shop said and rubbed off the rubbish rubber finish on the door handles, good advice
