Page 1 of 4
Sat Nav - mid Atlantic
Posted: Sun Jun 10, 2012 9:23 pm
by Daveperc
Ok, I know it's wet out there tonight, but just found Sat Nav has me placed somewhere mid Altlantic.
I know it's come up before, but I'm feeling lazy (an mildly frustrated!) tonight. Is it just the roof puck I need to change or is there something else??
Dave
Re: Sat Nav - mid Atlantic
Posted: Sun Jun 10, 2012 9:26 pm
by Shoppinit
Pretty sure it's the GPS antenna. Roof puck it is. Unless you want to put a different antenna somewhere else in the car to save the bother.
Posted: Sun Jun 10, 2012 9:31 pm
by Daveperc
Shop - that's what I thought.
I'll check it's plugged in properly at the back of the unit when I have it out to fit the xcar link and if that end's OK then a new puck it is. Think I'll stay OEM to save hassle.
Dave
Posted: Sun Jun 10, 2012 9:36 pm
by Shoppinit
I'm not 100% sure but I think you can unscrew the roof puck through the interior light to avoid messing with the headlining.
Posted: Mon Jun 11, 2012 6:45 am
by chunky79
Shoppinit wrote:I'm not 100% sure but I think you can unscrew the roof puck through the interior light to avoid messing with the headlining.
I believe you can. I mentioned it to someone and they did it ok.
Posted: Mon Jun 11, 2012 8:18 am
by Ryan_Pestell
you can. think its a 19mm nut.
Posted: Mon Jun 11, 2012 8:30 am
by Nobby
<Sat Nav lady>Turn left at the next Puerto Rico Trench
My Becker (See: Halfords Crap) has a tendancy to think I am about 200ft further West than I actually am. I hope the Atomic clocks in the satelites are working properly
Posted: Mon Jun 11, 2012 8:44 am
by Shoppinit
Nobby wrote:I hope the Atomic clocks in the satelites are working properly
Cheap american crap. Good job it's free.
Posted: Mon Jun 11, 2012 9:54 am
by MEV
Daveperc wrote:Thanks Shop - that's what I thought.
Dave
Yes it the roof GPS reciever went on mine recently. 70 odd quid gets you a fitted and stronger receiver in the dash by the boys at Hazzy Dayz, works very well, ask nicely and get a more recent disc to go with it.
Equally and while your at it have a look at having a new ipod interface installed perhaps Dave?
Posted: Mon Jun 11, 2012 11:15 am
by Ryan_Pestell
so gps puck behind the dash, and then you can use whatever roof arial you want? correct?
so i can fit my c6 arial even if it doesnt work, although it should, im just unsure of cable lengths, does anyone know where the standard c5, gps arial point connectors connect to the main car ? behind the CD changer?
Posted: Mon Jun 11, 2012 12:17 pm
by MEV
Yes if you have the puck in the dash the roof GPS reciever is rendered useless I believe so you can either remove it or have what you want there. Ive just put a stubby on there. The FM recievers for the rubbish radio are in the rear side windows IIRC. Not sure on the sizes etc but I expect the The
Shop will be along soon
Posted: Mon Jun 11, 2012 12:51 pm
by chunky79
The GPS unit on the roof holds the radio aerial on. The receivers in the side Windows aren't good enough on their own.
Posted: Mon Jun 11, 2012 1:00 pm
by Ryan_Pestell
cheers chucky, do you know where the standard C5 arial physically connect to the main loom? i.e half way up the C pillar or behind the CD changer etc etc.
the leads i have on my C6 arial are quite long but need to know where they physically connect on the C5, also anyone got any ideas how to get the C5 interior "C" pillar trims off?
Posted: Mon Jun 11, 2012 1:05 pm
by chunky79
Sorry mate no idea. If someone has elsawin then it should be visable on the pic I would have thought.
Posted: Sun Jun 17, 2012 6:35 pm
by RS6 Mugello
I am based in London and have a similar problem. Anyone know a good specialist in London ?
James
