Page 1 of 2
Water Leak
Posted: Thu May 03, 2012 5:19 pm
by barrybudden
Hi,
I'm new to RS6 ownership, I've been lurking here a while. I bought a car a week or so ago and noticed today that it has started to leak water, I saw a drip coming from the rear of the engine bay but I'm unsure from where exactly. Its not coolant or windscreen washer fluid. I have checked the levels and they are ok.
Re: Water Leak
Posted: Thu May 03, 2012 5:26 pm
by Maximo
It'll most likely be your Air/Con having a small pee. It's normal and nothing to worry about. There is a drain on the passangers side near the bulkhead, when it get's blocked you'll find the carpet gets wet and that's when you need to worry as the gearbox brain is down there.
We need to make sure you read the rules.
FON and pictures or it's not real.
Garry
Re: Water Leak
Posted: Thu May 03, 2012 9:37 pm
by bilko1
FON and rule one
Re: Water Leak
Posted: Fri May 04, 2012 1:25 am
by Shoppinit
barrybudden wrote:Its not coolant or windscreen washer fluid.
You tasted it, didn't you? Come on, you can admit it. We're all friends here. Well, some of us are. FON.
Re: Water Leak
Posted: Fri May 04, 2012 9:26 am
by chunky79
You say the levels are ok, how do you know the coolant wasn't over filled?
Re: Water Leak
Posted: Fri May 04, 2012 2:19 pm
by bam_bam
chunky79 wrote:You say the levels are ok, how do you know the coolant wasn't over filled?
What, no FON?
BTW.... FON.
Re: Water Leak
Posted: Fri May 04, 2012 2:59 pm
by chunky79
bam_bam wrote:chunky79 wrote:You say the levels are ok, how do you know the coolant wasn't over filled?
What, no FON?
BTW.... FON.
He is past 1 post so thought I was too late, Sod it
F O N
Re: Water Leak
Posted: Fri May 04, 2012 3:27 pm
by bam_bam
chunky79 wrote:bam_bam wrote:chunky79 wrote:You say the levels are ok, how do you know the coolant wasn't over filled?
What, no FON?
BTW.... FON.
F O N
This thread was his first post, as long as someone gets a FON in first, other members may continue to heap on the FON lovin'.
Re: Water Leak
Posted: Fri May 04, 2012 3:29 pm
by chunky79
Well I'm going to double post an
F O N
Re: Water Leak
Posted: Fri May 04, 2012 7:03 pm
by el_ringo
Any red colour to the liquid? Coolant will have a red tinge to it.
Re: Water Leak
Posted: Fri May 04, 2012 7:08 pm
by bam_bam
el_ringo wrote:Any red colour to the liquid? Coolant will have a red tinge to it.
Should he check the tampax compartment or the panty-liner?
Re: Water Leak
Posted: Fri May 04, 2012 7:11 pm
by el_ringo
LOL, red is gonna end your fun for days either way!
Re: Water Leak
Posted: Fri May 04, 2012 7:14 pm
by bam_bam
el_ringo wrote:LOL, red is gonna end your fun for days either way!
In your household maybe, in mine it's blowjob and anal week!
Re: Water Leak
Posted: Sun May 06, 2012 4:18 pm
by barrybudden
Yep aircon pissing on the yard.
Re: Water Leak
Posted: Sun May 06, 2012 4:22 pm
by grizz
It's quite normal for the ac to do this .
