C5 RS6 Vagcom - have I lost the plot?
Posted: Wed May 02, 2012 2:36 pm
by Scotland
OK, I've done loads of searches on here for previous posts but I still don't get Vagcom.
So all I need to do is buy this:
http://www.ebay.co.uk/itm/220518250615? ... 1423.l2649
download some shareware software and I have Vagcom? For £8?!
Am I missing something?
If so, then all I do is buy this instead?:
http://www.ebay.co.uk/itm/120902686393? ... 1423.l2649
or
http://www.ebay.co.uk/itm/170828541013? ... 1423.l2649
Sorry, go easy on me - I'm a newbie remember!
Re: C5 RS6 Vagcom - have I lost the plot?
Posted: Wed May 02, 2012 3:37 pm
by sweegie
Yep, the top link (blue cable) is what you want - this will let you run the
VCDS lite software available at the link below. Your bottom 2 links for hardware scanners are not what you want
http://www.ross-tech.com/vag-com/vag-functions.html
You can register
VCDS lite for $99 but probably for a quick scan as you don't own the car yet, you might get away with just the completely free version
I'd avoid any cables over 10 quid that claim to work with full
VCDS... if they are not direct from ross-tech or gendan (their uk distributor) they will be chinese clones. Ross tech are a great company and spending the cash on a legit ross-tech cable to support them is well worth it. As is buying a cheap as chips cable and registering
VCDS lite shareware
Posted: Wed May 02, 2012 7:44 pm
by RS6JJL
Yes the blue cable is what you want plug that into a laptop install the driver from the cd that comes with the cable
Next goto ross tech website and just download
VCDS-Lite this will enable you to scan the car for fault codes once installed
http://www.ross-tech.com/vcds/download/
any problems at all give me a shout
you do not want anything to do with those last two links you posted up ignore all that
Posted: Wed May 02, 2012 10:16 pm
by Scotland
Great stuff. I've ordered the top one so I'll let you know how I get on. I'll test it on the wife's golf tdi 1st!
Posted: Wed May 02, 2012 10:39 pm
by Nobby
Just ordered one myself - thanks. I'll give it a whirl on the neighbours A6
Is the OBD port in the usual place by the fuse boxes under the steering wheel?
Posted: Wed May 02, 2012 10:50 pm
by sweegie
Yep, it's right above your right knee cap
Posted: Fri May 04, 2012 5:52 pm
by bud-weis
Thanks for this post...I ordered that exact lead and downloaded the free software, just cleared my codes and took it for a run and happy to say no faults present when I read it again when I got back home.
