Page 1 of 2
RS6 C5: About to upgrade stock IC's to Wagners, what to log
Posted: Tue May 01, 2012 2:47 pm
by PatrickRS6
I've bought a set of Wagners, including the carbon air ducts and fog-light grills, also bought the reinforced hoses and clamps.
I suspect my OEM IC's to be leaking, so i wanted to log before and after with
Vagcom.
Logged the RPM, Intake air temp, Mass Air Flow G70 (Bank 1), Mass Air Flow G246 (Bank 2) & Mass Air Flow (G70 + G246)
Did a run on the freeway, 0-240km/h...
Will post the log, and footage from my VisionDrive.
Do i need to log more to be usefull?
Re: RS6 C5: About to upgrade stock IC's to Wagners, what to
Posted: Tue May 01, 2012 2:59 pm
by PatrickRS6
DOH! How could i forget to log the boost, will do that tonight, to much traffic now
Posted: Tue May 01, 2012 3:13 pm
by bakustax
I'd be surprised if you see much of a difference...from my understanding the main reason for the upgrade is to save the turbos rather than any performance gain
Posted: Tue May 01, 2012 4:05 pm
by PatrickRS6
Here's the video of the run, LOGs wil be posted later on...
http://www.youtube.com/watch?v=-ar2XDGeUO4
Posted: Tue May 01, 2012 4:08 pm
by Shoppinit
Cool. Is that near Osnabruck? Drive there quite a bit myself.
Posted: Tue May 01, 2012 4:10 pm
by PatrickRS6
It's in Holland, near the German border
A1 (Oldenzaal)... heading towards Germany (just a few kms)
Posted: Tue May 01, 2012 4:16 pm
by Shoppinit
Cool. Driven that route many times. Used to have a good friend in Nijmegen and I'd go that way on my way to Osna. These days I mostly use the E34.
Posted: Tue May 01, 2012 4:24 pm
by Nobby
bakustax wrote:I'd be surprised if you see much of a difference...from my understanding the main reason for the upgrade is to save the turbos rather than any performance gain
You might not see any performance benefits, but I cannot underestimate how important it is that if your intercoolers are leaking then your car is not running properly.
Air goes in, past the filter, through the MAF(s), ECU reads airflow and adjusts fuel trim/ignition accordingly. If subsequent air is leaked out past the turbos (or some gets in) then your ECU DOES NOT KNOW.
Posted: Tue May 01, 2012 4:26 pm
by PatrickRS6
One of the rare highways in Holland where you aren't stuck in traffic, unless its May 1st, like today, a few kms ahead the limit is 70 today due to the restriction for trucks on sundays in Germany. They were all parked on the emergency lane.
Don't know for sure, but i think we will pass Osnabruck on June 17th, the route is a well-kept secret, but the StreetGasm challenge will be passing Germany then, with a RS3, RS4 and a RS6 (the R8 V10 is still on the competitors list, but from what i've heard, it won't attend).
@Nobby: I know, that's why i also orderd new hoses and clamps, May 13th we'll drive 1100km to Reifnitz
Wörthersee Tour 2012
Posted: Tue May 01, 2012 4:34 pm
by bakustax
Nobby wrote:bakustax wrote:I'd be surprised if you see much of a difference...from my understanding the main reason for the upgrade is to save the turbos rather than any performance gain
Fair point...noted...would this show it's self in decreased MPG?...or would it be minimal with un-noticed damage being done
Posted: Tue May 01, 2012 4:54 pm
by Shoppinit
In closed loop mode then the lambda will detect the overrich mixture and compensate. Under WOT and in open loop then the ECU uses a guestimate for the mixture correction.
The real problem is that the turbos will not have enough resistance and risk exceeding their safe RPM leading to excessive wear. $$$
Posted: Tue May 01, 2012 6:44 pm
by JCviggen
Not correcting you, but I'm bored so i'll dwell a bit more on the mechanics of turbo's over-spinning: what happens when part of the charge air gets lost is simply that more air needs to go pass through the turbo to reach the same boost level. The wastegates stay closed(ish) until target boost is reached so the turbo itself basically has no choice but to spin faster than normal. Resistance aside, the reason they can over-spin is that the wastegate actuators are controlled by boost pressure. Vicious circle.
Over-spinning only occurs when you have a leak that is sigificant, but not so large that you're not making much boost anymore. A large leak that does not allow much boost will not spin turbos as high because there will be less (and less hot) exhaust gas available.
So it's the nasty little hard-to-notice leaks that will do them in after an extended period of time (MIL is likely however certainly on stock mapping)
Posted: Tue May 01, 2012 6:48 pm
by bakustax
So it's the nasty little hard-to-notice leaks that will do them in after an extended period of time.
Man this is exactly what we all miss...tricky stuff explained for the average Joe...great to have you back posting JC
Posted: Tue May 01, 2012 6:58 pm
by PatrickRS6
slightly offtopic, but bad mpg... haha been there.
Old TC: 4 km per liter
New TC: 6,5 km per liter
Posted: Tue May 01, 2012 7:02 pm
by bakustax
PatrickRS6 wrote:slightly offtopic, but bad mpg... haha been there.
Yup It's my guess too...It's not banging about but the MPG ain't great...15 in town and 25 on a run...it's inevitable.
