Kill Switch
stealthyspeeder
- 1st Gear
Kill Switch
I want to get a kill switch installed on my car, security at the apartment complex I live in chased off some car thieves the other night.
Now without anyone actually mentioning any location of where they would install a kill switch inside the car (the only people who will steal RS6's will be pro's who might do a bit of research), what all is involved?
Is it simpy just witing it to the loom to shut down the fuel pump the best way?
Re: Kill Switch
Problem with kill switches is that the thieves know ALL the places. I know this from experience, sadly.
Still, if you want then I would probably cut the ECU relay power. Or fuel pump. Or both. Depends how invovled you want to get.
Lots of things you could do to stop an RS6 running. The real trick is keeping them running
Re: Kill Switch
LOLShoppinit wrote:The real trick is keeping them running
Re: Kill Switch
Have you thought about one of these?
http://www.larkspeed.com/index.pl?a=i&k=s&p=13001ORGYEL
They are very good, if a bit ungainly; Don't bother with other types, has to be a full covering;
Re: Kill Switch
I'm sure one could think of a good place to hide the switch, but you have to interrupt the wiring somewhere (it's nearly always to the fuel pump which is the most straight forward) and that's a rather obvious place most of the time. If you do interrupt the fuel pump, make sure the wiring is up to the job there is quite a bit of current being drawn and it's easy to suffer a significant voltage drop to the pump.Shoppinit wrote:Problem with kill switches is that the thieves know ALL the places. I know this from experience, sadly.
I think mechanical locks work best. I've got one of these http://www.niedzwiedz-lock.pl/enblokada.php plus an electronic immobilizer that cuts both ECU and the fuel pump (thinking of getting rid of it though as it has stalled the car while driving several times when it couldn't see the credential for a few seconds)
981 Cayman GTS Gray/Orange.
My youtube
My youtube
Re: Kill Switch
You probably wouldn't cutr the power to the fuel pump, but to the fuel pump relay, but then yuo could just short circuit the relay to get the pump going. I think the RS6 fuel pump is pulling a lot of current;
I like the gear lock. I was thinking about a switch that would cut power to the gear lever solenoid. That would have a similar effect.
stealthyspeeder
- 1st Gear
Re: Kill Switch
Thanks for the info!
Im thinking that the car is basically not going to get stolen without the key. Where its parked, there is security on patrol at home and in work, and anyone seaking to steal it without the key would have to spend a bit of time and know what they were doing.
So what I had in mind was something that cut the car out after after they had got far enough away to not come back. I wouldnt want myself and the missus safety put at risk if someone broke during the night into get the keys, then found it wouldnt start and came straight back to make me start it. My friend has an Interga (thief magnet) and he has a little panel which he hits a 4 digit code into each and every time he starts the car (has to be done within a minute), if its not input, the car cuts out and the alarm goes off.
Anyone got or know of anything similar?
Re: Kill Switch
I wish that were true.stealthyspeeder wrote:Thanks for the info!
There are plenty of anticarjacking alarms available where the immombiliser will cut in after a mile or so.
stealthyspeeder
- 1st Gear
Re: Kill Switch
Was yours stolen quickly, without the key and a kill switch??
Re: Kill Switch
Not my RS6. But otherwise yes and yes.
Kill switches are a bit of a joke. Car theives will find them very quickly unless you get very very inventive; Better than nothing though.
Get the steering wheel lock. It's a royal pain in the ass for a thief and will probably make him move on.
Or both.
Ultimately, though, it's only a car; Better hand them the keys if they come asking.
Or both.
Re: Kill Switch
Take your flat number off the parking bay (assuming they didn't number them sequentiality) I did that when I lived in a flat and so did other residents so they would have a hard time getting right the flat for the keys.
I also use a steering wheel lock just to show a potential thief that I am expecting them and keep the glove box and arm rest open and empty. I had the pleasure of busted glass one morning in London.
Protecting your keys is the main way to protect the car but don't forget it is better the car goes than getting hurt.
(It would appear from recent events in the news that if four blokes come into your house you can't defend yourself!
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!!
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
**** SOLD!!!
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Unit 20 TCU remap
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
Tesla Model X 60D
Cornishmoocher
- Top Gear
Re: Kill Switch
Talk to Rich at Viper tuning..... he has a wicked system..... was going to put it on my 6.
Its totally brilliant and the concept is simple, but effective.
It's all Bollox.
perthwaRS6
Re: Kill Switch
Switchable APR tune comes standard with immobiliser. Needs code activated through cruise control to start engine. If correct code not entered, engine will turn over with key, but will not fire. Check out APR web site. Immobiliser kicks in if battery removed. This then tests owners memory of method of correct code setting procedure!
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
Re: Kill Switch
Yeah, but I would have to sell a kidney to buy an APR tune.
I'm hearing good things about viper.
Re: Kill Switch
My idea of a 'kill switch' involves a button you press after the horrible scrote has driven away, 50,000 volts, the seat heating filament, and a very scorched one of these --->
Users browsing this forum: No registered users and 272 guests
