error codes
Posted: Mon Apr 04, 2011 9:22 am
by Gravitypilot
Guys...
got 2 error codes can you help?
19497
17983
Re: error codes
Posted: Mon Apr 04, 2011 9:26 am
by mavada
19479: Powertrain Databus, Implausible Engine Temperature Message from Inst.Panel
17983: Right Engine Mount Solenoid Valve, Short to B+
Re: error codes
Posted: Mon Apr 04, 2011 11:59 am
by Shoppinit
The 1st one sounds like water infiltration into the can bus module under the passenger side carpet. Check for blocked drains and wet carpet. I can't see it being anything else.
The 2nd one could be related to the first, or might indicate a dead engine mount. Can be changed relatively easily or left alone. I remember seeing a connector you could buy to fool the ECU into thinking it was still working.
Personally I'd replace it. If they bothered to go to the trouble of putting active engine mounts in, then I'd make sure it works :thumbs:
Re: error codes
Posted: Mon Apr 04, 2011 1:04 pm
by JCviggen
Shoppinit wrote: Personally I'd replace it. If they bothered to go to the trouble of putting active engine mounts in, then I'd make sure it works :thumbs:
They did put a few things into the RS6 that are questionable at best though :audibash:
Re: error codes
Posted: Mon Apr 04, 2011 1:21 pm
by Shoppinit
JCviggen wrote: They did put a few things into the RS6 that are questionable at best though :audibash:
Jamiroquai for one...
